    2D Multi_filet?
    5 Posts 3 Posters 363 Views 3 Watching
    • urgenU Offline
      urgen
      ...Guys, I can not find the plugin ... I think that it does not exist πŸ˜’ ... I know such a tool in the 2D-tools .... it is useful for 1-5 action .. but if their number is 50 (for example), and more? πŸ˜•
      ....the action :
      ... Select lines (or lines and face),activate tool,set the parameters(segments,radius),visually check the settings and press "enter"...
      ...or... is it possible to do this for work similar to the standard sketchup "offset"tool? πŸ˜•
      --pupil forever...------
      • jeff hammondJ Offline
        jeff hammond
        2d fillet by ohyeahcad will do this.
        Page not found – Villkor pΓ₯ casinon | Hitta ditt nya favoritcasino
        (www.ohyeahcad.com)
        so will fredo's BezierSpline.
        dotdotdot
        • urgenU Offline
          urgen
          ...thanks Jeff!
          ...the problem is solved πŸ˜›
            jeff hammond
            @urgen said:
            ...thanks Jeff!
            the problem with the ohyeahcad version is you can't adjust the amount of segments..
            with bezierSpline , you can
            (select all the edges.. right-click --> BZ- convert to --> Polyline Arc Corners..
            enter the offset amount… then enter something like 12s in the measurement box (which will give you 12 segments in between control points)
            dotdotdot
              Interesting posts! β˜€
