    Drop plugin?
    3 Posts 2 Posters 380 Views 2 Watching
    • E Offline
      essendeenut
      Linear problem.
      Dear All,
      I am trying to make a railway cab-ride view animation and am a bit stuck with the track. I have lots of gradient changes and curves which I’ve smoothed out using roundcorner. I have then draped the imported image traced tracks and draped them onto the β€œtrackbed”
      But I now want to use pathcopy to copy a railway sleeper and its attached pieces of rail along the undulating and curving path so I may then go back and make each 30 inch component unique and rotate it in 1/8 inch increments to give the effect of transition camber on various curves (super elevation)
      I cannot think of any other way to do this. But my problem is the drop plugin, as far as I know, only drops an object onto a level planing. This is no good if I want to drop a sleeper / rail component onto the plane of a gradient.
      Any ideas?
        Seems you have a drop plug at intersection at right click πŸ˜‰
        But yes the object don't align to the slope
        We must find another trick πŸ˜‰
        Component onto face by Chris Fullmer ?
        But yes that put the object just at the middle of the face πŸ˜‰
        Smart drop ? by a4architect
        http://forums.sketchucation.com/download/file.php?id=23208&mode=view
        Ray Tracer ? by Thomthom
        http://forums.sketchucation.com/download/file.php?id=53900&t=1
          Or this post ?
          else the Thomthom Ray tracer / Components by Bounds above works very fine
          but without image from you I have some difficulties to see what you want 😳
          Components or groups must be horizontal above the object before the drop !
