    Convert Model material/colors by layer to applied materials
    3 Posts 3 Posters 8.8k Views 3 Watching
    • E Offline
      ek12
      I use AutoCAD to generate most of my architectural model information, then do some tweaking, or design refinements in SketchUP, export images and do some post-production render in Photoshop. Since I have been doing this over 30 years (straight AutoCAD in early years) I have always controlled my model and materials by layer as that is how I work/think in ACAD.
      I have a lot of models with materials applied by layer and would like to simply convert the model to have the same materials applied/painted to the same surfaces to render with SU, or plug in rendering software. Anybody know of a quick solution? Thanks. EK
        I am not sure but how about this plugin?
        http://forums.sketchucation.com/viewtopic.php?t=36715
        • maxhouserocksM Offline
          maxhouserocks
          Just found this post. Had same problem and had trouble finding a solution. Here is my documentation on it:
          IN SKETCHUP -- Use a script to Paint faces of model with materials based on their layer.
          • If you need to work with materials in SketchUp, then do the following to materialize faces based on layer designation:
          • Download -- layers_materials.rb -- (Script By: Didier Bur) to paint faces with layer color:
            Layers Materials: http://rhin.crai.archi.fr/rld/plugin_details.php?id=219
          • IMPORTANT! After loading script, you must first run “CREATE MATERIALS FROM LAYERS”
          • Then, run “PAINT FACES FROM LAYERS”
          Full description here:
          http://sketchucation.com/forums/viewtopic.php?f=18%26amp;t=65107
          Robert A. Christman
          http://rachristman.blogspot.com/
