    Probably a no-brainer...extruding a curve making me crazy!
    4 Posts 3 Posters 234 Views 3 Watching
    • W Offline
      winesellar10
      Hi Everyone,
      I know this is probably totally a no-brainer and I hesitate to even post it here because I know that it should be simple, but I am having a heck of a time getting what I need to get done. I have tried, among countless other things:
      1. Extruding along the path
      2. Using the "convert lines to circles, etc" plugin
      3. Can't figure out how to get the shape bender plugin to work!
      But I still can't get the complete curve. I know that the section on the right the problem is probably due to the many sections that make that curve, but I can't figure out how to make the curve without them!
      Thank you all ahead of time for wasting your brain space and time for helping me out on this!
      Oh, see the attached skp file for what I am talking about!
      curve help!.skp
        mrossk
        I think the problem is the scale of your model. Sketchup doesn't like tiny faces. Try scaling up by 10 or even 100x ,extrude, then scale it back.
        https://www.mkaplanfinefurniture.com/
        • BoxB Offline
          Simple answer, It's too small, scale it up by 10 or 100 and have another go.
          Edit, too slow I am.
          • W Offline
            winesellar10
            It worked!! I knew it had to be something simple like that!!
            Thank you both for your quick help!
