    Question - Plugin to Follow Me At Path?
    4 Posts 3 Posters 297 Views 3 Watching
      jfjohnny5
      Follow Me pulls a shape out along a path, but starts at the shape. So if the shape isn't at the path's endpoint, it just pulls out from the shape. Is there a plugin out there that allows you to have the result occur at the path location instead?
      • jeff hammondJ Offline
        jeff hammond
        there's another way to use the follow me tool that i suppose you're unaware of.
        -select the path first
        -choose the follow me tool
        -click on the profile face
        this way, you don't have to manually drag the profile along the path.
        doing it this way will also allow you to do what (i think) your question is asking.
        dotdotdot
          Yes Extrude Edges by Face by Tig
          But the "face" must be drawn "flat" (as a top view) !
          http://forums.sketchucation.com/download/file.php?id=42809&mode=view
            jfjohnny5
            That draws the resulting form using the face as a starting point. In other words, if the path is 20' away it will start at the shape. I want it to start AT the path.
            In practice I have a series of curves drawn along a curved face. I want to extrude a shape along each of those curves. If I could just define the profile curve once and then have it extruded starting at each path's location, that would be ideal. Make sense?
            I'm going to look at Tig's plugin. Hopefully that will save me from having to place the profile curve at the start of each path individually.
