    Open Component Options window with Ruby?
    6 Posts 3 Posters 767 Views 3 Watching
    • D
      descoteaux
      I'm trying to create a custom tool in Jim Foltz's Custom Toolbar. It simply needs to open the Component Options window when clicked. Unfortunately there doesn't seem to be a Sketchup.send_action value to do so. Is there an alternative way to accomplish this? Thank you.
      • TIGT
        See https://developers.google.com/sketchup/docs/ourdoc/sketchup#send_action
        Sketchup.send_action(21060) Sketchup.send_action(21086)
        PC only
        • D
          descoteaux
          Thank you for your help. I've actually already explored that list and I believe the Component Options window is not on it. Those send action values aren't it.
          • Dan RathbunD
            Dan Rathbun
            id 21086 is assigned to the "Purge Unused" menuitem, on the Components Manager Popup menu.
            I'm not here much anymore.
            • Dan RathbunD
              Dan Rathbun
              And...
              id 21060 opens the Components Manager Inspector (toolwindow,) NOT the DC Component Options (WebDialog) window.
              Instead call:
              $dc_observers.get_latest_class().show_configure_dialog()
              or to close it:
              $dc_observers.get_latest_class().close_configure_dialog()
              You will need to add a defined?($dc_observers) check (perhaps as part of the toolbar button validation proc,) to be sure that Dynamic Components are loaded, and perhaps a require("dynamiccomponents.rb") if they are not. (Still a user may have them turned off in the Preferences dialog.)
              • D
                descoteaux
                Excellent! That did the trick Dan, thank you!
