    Fill component with lines
    4 Posts 2 Posters 320 Views 2 Watching
    • M
      motleypower
      Hello,
      I'm new here although I have been playing around with ruby & vba on and off for a couple of years
      I want to be able to "fill" a component with parallel edges so they form a grid. I've managed to write a very basic repeater that can draw a grid of lines and then I can manually drop a component into the box of lines and then intersect all the lines and then cut off all the ends but how can I make the code do the fill without having to go through all of that.
      Maybe the code would do all of that or maybe it would be smarter and only put lines where they were required in the first place
      Here is what I've written so far, if you set the parameters too high it hangs up
      I work in mm with accuracy 0.1mm in the units settings
      prompts = ["Scan spacing?", "x axis max?", "y axis max?", "z axis max?"]
      defaults = ["0.1", "10", "10", "10"]
      list = ["0.1|0.2|0.4","10|20|30","10|20|30","10|20|30"]
      input = UI.inputbox prompts, defaults,list, "Set up lines."
      scan = input[0].to_l
      xmin = 0
      xmax = input[1].to_l
      ymin = 0
      ymax = input[2].to_l
      zmin = 0
      zmax = input[3].to_l
      lines = (xmax/scan)
      UI.messagebox (lines)
      UI.messagebox (scan)
      while zmin < zmax
      while ymin < ymax
      pt1 = [xmin,ymin,zmin]
      pt2 = [xmax,ymin,zmin]
      ymin += scan
      Sketchup.active_model.entities.add_line(pt1,pt2)
      ymin = 0
      zmin += scan
      Any pointers in the write direction would be great.
      thanks , Tom
      demonstration of lines
      • J
        Jim
        Hi Tom,
        There is a plugin named Hatchfaces that sounds like it would meet your requirements.
        404 Not Found
        (forums.sketchucation.com)
        • M
          motleypower
          Jim,
          hatch faces looks to be area only. I am trying to do volume. The script I wrote works to generate the box but how would I perform an intersect & trim extents command in ruby so I'm just left with the volume of the component filled with an array of lines ?
          Regards ,
          Tom
          • M
            motleypower
            I think I'll re visit that area plugin, maybe it can be tweaked.
