    When I export collada file from Skechup Pro 8 to Lumion 3D
    extensions
    4 Posts 3 Posters 13.8k Views 3 Watching
      Blanca
      Hi guys
      Can anyone help me please!!!
      I tried to export Sketchup to Lumion. I did it exactly as usually but with this model after I place it I can't see it. If I try with other model is not a problem. I'M USING COLORS NOT TEXTURES BUT STILL IS MISSING my model . i can see only the dot. Where the hell is my model? Any suggestions please?
        All your model is groups or componants for have possibility to give them some material?
          My guess is that your model is far from the world origin in SU. Lumion uses the SU origin as insertion point in its model space. After inserting (and seeing nothing), look around in Lumion and see if it is not "behind" or "above" you.
          Best practice would be to move your model to the origin - preferably snapping an edge or corner point (that should be lying on the ground) of your model to the origin.
          Another thing can be that even if you are "below", if you are seeing back faces from below and they are not textured, they are see-through in Lumion. In any case, navigate away a bit in Lumion and look around to "find" your model.
            Something who is some difficult is to have a "view top" 😳
            And edit : you are not obliged to have component or group for give different material to a cube with different colors! β˜€
