    Create360 plugin issue
    6 Posts 2 Posters 244 Views 2 Watching
      dskogg
      Hi anyone know how to get rid of this plugin? I deleted it from the plugin folder and
      i keep getting a bunch of scenes come up when ever i start a new file?
      its driving me crazy!
        Though I am not sure which plugin that is, if you now have a bunch of scenes whenever you start a new model, it seems that it has overwritten your default template. Just delete all the scenes you do not need and save the empty file as a template under the File menu. If you leave the checkbox at the bottom left of the dialog checked, your next model will start with a template without the scenes.
          dskogg
          thanks for the quick reply, i have tried saving as a new template with the scenes erased and they keep coming back?
            Did you also make sure to use that new template as default? What happens if you choose any other template under Window > Preferences?
              dskogg
              Do you mean once i have started su? I tried selecting another template as you mentioned but scenes do not go away.
                Then something of that plugin has remained there. Look again and make sure you have indeed removed it. Even remove (copy) all your plugins and start by adding the "know ones" back (and always restarting SU).
