    I need bending help...
    3 Posts 3 Posters 1.8k Views 3 Watching
    • N Offline
      ninopiamonte
      Hi guys. I need a help with this simple prob.
      I'm making a background grid, and here is the first step I'm doing...
      Second, I'm going to bend the half of it..
      And here, you can see it not rightly mapped with the texture..?
      Though, I used Fredo Scale for the bending.
      I also used Round Corner tool.
      Thanks....
      • tridemT Offline
        tridem
        when you rotate a geometry the texture mapping is rebuilded, you should unfold/refold the surface πŸ˜• that is not a simple work in SU... I would follow this way suggested by Gaieus http://forums.sketchucation.com/viewtopic.php?p=281409#p281409
        • dukejazzD Offline
          dukejazz
          UV_Toolkit
          by thomthom
          UV mapping automation:
          • tries to fit the texture of the current material onto all quad-faces in the selection. The texture should fit once across the face, no tiling.
          • Rotates the orientation of the textures on the quad-face,
          • Transfers the material from one side of the face to the other. UV mapping will be mirrored.
          UVtools
          by D. Martens
          Sections: Edit ; Materials - Rendering
          Cylindrical and spherical mapping on surfaces.
          UV Projection
          by J. Sandstrom
          Can easily fix messed up UV's by projecting planar UVs on a selection in either X, Y or Z axis.
          Cylindrical UVtools may work best
