    Concatenating text elements
    3 Posts 2 Posters 823 Views 2 Watching
      Buckyman
      SketchUp Version: 8
      I am trying to create an Item Code thusly:
      ="6072"&if(PatioCover!BeamHt<=96,"08",if(PatioCover!BeamHt<=120,"10",if(PatioCover!BeamHt<=144,"12","14")))&PatioCover!PostCol
      should result in 607208WH
      but what I get is 60728WH
      Completely illogical esp. since I have everything in quotes and esp. since the last item in the formula resolves to "WH" which would force any spreadsheet (for example) to identify the result as text.
      • DareDevilD Offline
        DareDevil
        @buckyman said:
        SketchUp Version: 8
        I never experienced this problem !... but I never use & 😉
        I prefer use CONCATENATE function, and your problem is solved, a "0001" is really "0001" not "1"
        So your function will be something like
        = CONCATENATE ("6072", if(PatioCover!BeamHt<=96,"08", if(PatioCover!BeamHt<=120,"10", if(PatioCover!BeamHt<=144,"12","14"))), PatioCover!PostCol)
          Buckyman
          Well that's a bit embarrassing, I guess I should have checked out the available functions.
          Thanks for your help!
