    Glass Block Lamp
    13 Posts 6 Posters 2.0k Views 6 Watching
    • HieruH Offline
      Hieru
      This is an offshoot from the work I did on the Glass brick/block thread. It's based on Harri Koskinen's Block Lamp and rendered with Thea render.
      Here's some views of the SU model:
      www.davidhier.co.uk
      • jason_marantoJ Offline
        jason_maranto
        Cool! πŸ‘ πŸ‘
        Love the bubbles too -- great modelling and render. β˜€
        Best,
        Jason.
        • soloS Offline
          solo
          That's cool.
          Initially I thought it was a light inside a hollow glass block with water inside, I see it's two solid glass blocks with an indentation for light bulb. πŸ‘
          http://www.solos-art.com
          • EscapeArtistE Offline
            EscapeArtist
            Very cool!
            • N Offline
              ninopiamonte
              Where can I download this one in .skp? πŸŽ‰
              • HieruH Offline
                Hieru
                Thanks guys πŸ‘
                Glad you like the model and render. It was equally fun and frustrating to work on. I thought I could just put it together quickly with a proxy and Artisan but the bevel I wanted between the recessed bulb shape and the block just wasn't happening. In the end I had to model the block and bulb recess separately and combine them together.
                Not an ideal solution and a bit of a bodge job really 😳. I suppose the main thing is that it works for the end result, but with a bit more experience I'd like to come back to this and find a way of producing a nicer mesh.
                @ninopiamonte
                Given the time invested in the project and the fact that I'm not 100% happy with the modelling I don't have any plans to share the model. Sorry.
                I would however be happy to talk you through the modelling process if you are interested in having a go yourself.
                www.davidhier.co.uk
                • N Offline
                  notareal
                  This been one of my favorite lamp for long! Did even modeled it years ago πŸ˜„
                  • HieruH Offline
                    Hieru
                    It's been on my radar for a while but I'd completely forgotten about it until Pete started the glass block challenge. I've fallen in love with it all over again and it's now on my 'must have' list.
                    It's not this one in the 3D Warehouse is it?
                    www.davidhier.co.uk
                    • N Offline
                      notareal
                      Nope. Did never published it and skippy is probably lost in void. Some Kerkythea test render from 2007:
                      http://www.kerkythea.net/forum/download/file.php?id=10
                      • HieruH Offline
                        Hieru
                        I had a feeling it wasn't your model.
                        It's a pity you've lost it as I would have liked to have seen your approach to the modelling. Interesting render by the way - it shows quite a lot of potential for using the lamp in proper scenes.
                        www.davidhier.co.uk
                        • N Offline
                          notareal
                          Needed to look trough backups... here is the wire-frame. Quite coarse and not that accurate to original. But that five years ago... a blast from the past. No Artisan πŸ˜‰
                          • HieruH Offline
                            Hieru
                            Thanks for taking the time to dig out the old model. Looks pretty good considering you didn't use Artisan or SDS and it makes me wonder if I needed to bother with the bevel around the bulb-shaped recess.
                            www.davidhier.co.uk
                            • N Offline
                              notareal
                              If I where modelling this, I'd add the bevel. Naturally also a treatment with artisan. Also topology was a mess. Here is some good reference photos, if you still need http://tiinaliisak.wordpress.com/2011/03/30/jasper-johns-light-bulb-vs-harri-koskinen-block-lamp/
