    Auto create an given item at a calculated location? See insi
    2 Posts 2 Posters 202 Views 2 Watching
    • A
      aaronxia00
      Hi, all! I'm a student currently writing a program that could determine optimal location for an item. The question I had is that is it possible to automatically create an given item at a calculated location, for say, the central point inside a cube. More precisely might be how to obtain the number of items, ex. walls, between two given points, and attributes associated with them.
      Thanks for helping!
      BING
      • TIGT
        I suggest you read the API... https://developers.google.com/sketchup/docs/
        The entities.add_...() methods do want you want...
        You'll also need to understand Transformations [simple will do!] used to locate some things like 'instances'... and how to create objects like Point3d and maybe Vector3d...
        There many freely available snippets and full-scripts, that already do what you seek, so there's no need to reinvent the wheel from scratch - just understand what you are doing...
        I might move this into the Developers' Forum...
        [EDIT: done.]
