    How do i radius an outside corner on an pushed in box
    3 Posts 2 Posters 214 Views 2 Watching
      jakemiester3
      hope this makes sense....If i was to draw a 3dimensional box and then draw a smaller box on one side and push it in I would be left with four corners. I would like to radius the four corners and I cant figure out the best way to do this or if its possible. I understand you can radius the outside corners of the outer box by drawing arc and use follow me tool but there is no where to draw an arc on the inside corners. Any ideas???
        I am not sure about your envisioned shape (note that you can alwys attach images or even skp files) so this is my try guessing what you mean:
        Note that for a Follow me operation (despite the SU manual and the SU warnings when doing it), the profile does not necessarily have to be at the beginning of (or on) the path.
        I also attach the file so that you can try.
        InnerFollowMe.skp
        Then, when you are done with learning to do things like this, we can also have a look at some useful plugins that o any kind of rounding anywhere you like easily. See below...
        [flash=600,400:6rvo6rex]http://www.youtube.com/v/q3LBWfLNopE[/flash:6rvo6rex]
          jakemiester3
          Wow thats awesome. Thanks for the info. I am going to play with this and see if I can apply it to what I am doing.
