    Download Plug-In
    7 Posts 3 Posters 391 Views 3 Watching
    • F Offline
      felipe.sabino
      Hi all!
      First, sorry about my english.
      So, i have a site with some zipped components (.tar.gz) and i want to make a plug-in for download this components.
      Actually my plug-in make the component download, but it's instable.
      I using the follow code:
      <span class="syntaxdefault">def&nbsp;download_product_http</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">param_1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">param_2</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">param_3</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">param_4</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">dialog</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">param_5</span><span class="syntaxkeyword">)<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">Net</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">HTTP</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">RESTRICTED_HTTP_SERVER</span><span class="syntaxkeyword">)&nbsp;{&nbsp;|</span><span class="syntaxdefault">http</span><span class="syntaxkeyword">|&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;SET&nbsp;HTTP&nbsp;SERVER&nbsp;FOR&nbsp;DOWNLOAD<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">response&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">http</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">request_head</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">URI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">escape</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">LINK</span><span class="syntaxkeyword">))&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;SET&nbsp;THE&nbsp;LINK&nbsp;AT&nbsp;THE&nbsp;HTTP&nbsp;SERVER<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">file_size&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">response</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'content-length'</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_i&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;FOR&nbsp;PROGRESS&nbsp;BAR<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">open</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">product_tar_gz_name</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"wb"</span><span class="syntaxkeyword">)&nbsp;{&nbsp;|</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">|&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">http</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">URI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">escape</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">temp_link</span><span class="syntaxkeyword">))&nbsp;do&nbsp;|</span><span class="syntaxdefault">str</span><span class="syntaxkeyword">|&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">write&nbsp;str<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;CODE&nbsp;FOR&nbsp;INCREMENT&nbsp;PROGRESS&nbsp;BAR&nbsp;AT&nbsp;WEBDIALOG<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}<br /></span><span class="syntaxdefault">end</span>
      This code works well for tar.gz files until 1 mb, when the size of the files exceeds 1 or 1.5 mb SKU crashes... i really dont know why...
      I've tried using the "model.definitions.load_from_url(url,handler)" but this works only for SKP files.
      I've looking for something more simple, someone with any idea?
      Thanks.
      Felipe
      • Dan RathbunD Offline
        Dan Rathbun
        Have you tried the new rbz (zip format,) to put the components in a subdir of "Plugins", then move them to another folder after the extension installer unzips them ??
        I'm not here much anymore.
        • F Offline
          felipe.sabino
          I do not know if I understand What you said, but here we go.
          1 - I cant change the compress format of the components, there is to many components and is the default of my company.
          2 - I've tried to download the file in the subdir "...\Google SkethUp8\Plugins\Components" for then move them to the correct folder, but the SKU still crashes while download is in progress..
            Dan Rathbun
            Have you tried using FTP protocol ??
            See the Net::FTP standard library.
              Instead of trying to deflate the compressed file as it arrives and finding it exceeds some size limit for this... why not download the compressed files into a temporary folder then use a 'command-line' cmd type file to extract their contents [most decompression apps have command-line options]... finally move the extracted files to their final destination, and tidy up by erasing the unneeded compressed files and their temporary folder...
              • F Offline
                felipe.sabino
                I have ftp implemented too.
                I always try do download from http, if it fails then i try to download from ftp and it fails too. ( i cant use always ftp because in some client machines the ftp is blocked.)
                The weird is because during the download, SKU crashes in a feel machines, not in all... In my machine for example its always well succeed
                  Dan Rathbun
                  Since he is using the extended Ruby libraries, with a full Ruby install...
                  @tig said:
                  Instead of trying to deflate the compressed file as it arrives ... why not download the compressed files into a temporary folder ...
                  Net::FTP
                  @tig said:
                  ... then extract their contents ...
                  Zlib
                  FileUtils
