    "Centered" Repeating Sub-Components?
    3 Posts 2 Posters 614 Views 2 Watching
      SUFractal
      Hello:
      I'm trying to figure out the commands/formula for "centering" the position of repeating subcomponents, along one axis of dynamic component. I want the total number of sub-components to be equally spaced from each end of the overall length of the component, no matter what the length is. I am assuming the repeating subcomponent should not be constrained (position-wise) along that axis?
      Does my explanation make sense?
      Any help would be much appreciated!
      • DareDevilD Offline
        DareDevil
        I don't know if I really understand your request, but here is my answer 😉
        Distrib.skp
        There is a component in a component, you choose the number of sub component and you can stretch the mastercomponent along the red axes. The sub components will be placed at
        X = Copy * (Master!LenX - LenX)/(Copies + 1)
        You must fix the LenX of the sub component to avoid to transform them when you resize the master component.
          SUFractal
          [attachment=0:6mcjm8ou]<!-- ia0 -->Distrib.skp<!-- ia0 -->[/attachment:6mcjm8ou]
          I'm trying to do something similar to some of the typical fence direct components (DC's) that are floating around.
          I have LenX of the subcomponent fixed, and the number of them is being determined by dividing the Master!LenX/LenX. Additionally, I'm trying to use the 'INT' math function to round-down the number of repeating SC's, to keep the total length of them to less than Master!LenX.
          LenX is also the "spacing", as the sub-components are touching each other, so there is actually no space between them.
          Thanks.
