    Ruby access to global delay_time and transition_time
    3 Posts 2 Posters 180 Views 2 Watching
      sanghgo
      I would like to read from a Ruby script the global value of the delay_time and transition_time found in the scene manager window, but that does not seem to be possible. The methods Page.delay_time and Page.transition_time only allow access to delay and transition times for each page that can be access independently and reports a value of -1 to refer to the global value.
        sanghgo
        TIG, thank you lots, that worked!!!
        I can't tell you how exhaustively I've searched the API, SketchUcation and Google with no luck.
          <span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">options</span><span class="syntaxkeyword">[</span><span class="syntaxstring">"SlideshowOptions"</span><span class="syntaxkeyword">][</span><span class="syntaxstring">"SlideTime"</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">options</span><span class="syntaxkeyword">[</span><span class="syntaxstring">"PageOptions"</span><span class="syntaxkeyword">][</span><span class="syntaxstring">"TransitionTime"</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span>
