    Script to bring all components from library into SU model
    23 Posts 3 Posters 2.3k Views 3 Watching
    • S
      samyell77
      Wonder if anyone can help me to find or write a script that will allow me to bring all of the components from a component library into an SU file. Ideally I'd like to be able to place them next to each other in a line or on a grid (say 1000mm grid).
      Is this possible to do?
      Sam
      SU Pro 2016
      Dell Precision M4800
      PC Windows 10
      Intel Core i7-4900MQ @ 2.80ghz
      Nvidia Quadro K2100M
      16gb RAM
      • TIGT
        It's doable.
        Set up some initial references etc
        ` skpfolderpath='C:/temp/my_compos'
        OR wherever the SKPs are...
        model=Sketchup.active_model
        ents=model.active_entities
        defs=model.definitions
        pt=Geom::Point3d.new(0,0,0)You iterate through the contents of that folder and every SKP is loaded in turn thus. skps=[]
        Dir.foreach(skpfolderpath){|f|skps << File.join(skpfolderpath, f) if File.extname(f).downcase==".skp"}then load from the list of SKPs... skps.each{|skp|
        defn=defs.load(skp)
        } You have a reference [ defn] to the definition each time... so at ###*** add the code to place an instance after it's loaded thus [checking that 'defn' successfully loaded before trying to pace an instance at ###!]: next if not defn ###!
        tr=Geom::Transformation.new(pt)
        inst=defs.add_instance(defn, tr)and immediately afterwards relocate the point 'pt' thus: pt.x=pt.x+1.m`
        The next instance will then be put 1m to the right, because the transformation 'tr' will use the changed values for 'pt' each time etc etc...
        • S
          samyell77
          Hi TIG,
          Thanks for looking at this - have been busy with other projects so haven't had time to take another look at this until now. Ive run through the first part of your script
          and get this message from the console
          Running the code...Done. Feedback from Ruby: (0mm, 0mm, 0mm)
          Then I iterate through the contents of the folder which loads the components into the models component list.
          Then I pasted the next part of the script into the ruby console
          skps=[]
          Dir.foreach(skpfolderpath){|f|skps << File.join(skpfolderpath, f) if File.extname(f).downcase==.".skp"}
          Running the code...Done. Feedback from Ruby: Nil result (no result returned or run failed)
          Not quite sure what is supposed to happen at this point and wonder if you could clarify for me.
          Also on the next part of the script where you refer to definitions Im not sure what I need to put in in place of ###***
          Sorry if this is all totally obvious - ive re-read your post many times over and Im afraid I cant work out what to do next.
          SU Pro 2016
          PC Windows 10
          16gb RAM
          • TIGT
            There was a typo in the code, it should be
            There was a rogue '.' πŸ˜’
            So 'skps' is empty !
            Try with the adjusted version [I edited the post!]
            πŸ˜•
            I assume you are using a MAC because a PC won't accept multiple lines in the Console...
            • S
              samyell77
              Thanks TIG
              Copied and pasted from the edited post and now get this message from the console
              Running the code...Done. Feedback from Ruby: Run aborted (error has occurred)
              Do I need to start over and re-load the components into the model?
              SU Pro 2016
              PC Windows 10
              16gb RAM
              • TIGT
                skps=[]
                skps.each{|skp|defn=defs.load(skp);###} This *should* load the defns from the folder. Does it ? If you want to place instances use the extra code on ' defn', inserted into the {} block at ' ###`'
                • S
                  samyell77
                  Thanks again TIG
                  skpfolderpath='C:\Users\sam.morris\Documents\TEST COMPS'
                  skps=[]
                  Pasted all this in in one go and still get a Nil result - . Thought I'd try with a small, local component folder so copied some SKPs onto into a folder in my documents folder and pasted the path into your script. Have tried this with '/' and '' separators cos I remember there was an issue with that previously on another script you looked at for me.
                  I had been working through the script in sections previously but this time pasted it all in - is this correct or do I still need to iterate down (manually) through the components in the components library before running
                  skps=[]
                  Sorry to keep coming back . . . with a nil result 😳
                  Hope this makes sense
                  SU Pro 2016
                  PC Windows 10
                  16gb RAM
                  • TIGT
                    Try a simple test first
                    skpfolderpath='C:/Users/sam.morris/Documents/TEST COMPS' Dir.foreach(skpfolderpath){|f|puts f}
                    Do you get a list of the folder's contents printed, include '.', '..' and all files ?
                    If so try this
                    skps=[];Dir.foreach(skpfolderpath){|f|skps << File.join(skpfolderpath, f) if File.extname(f).downcase==".skp"}
                    Do you get a list of just the SKP files when you then type skps?
                    If so we have got the list and just need to 'load' the SKPs...
                    πŸ˜•
                    • S
                      samyell77
                      Hi TIG,
                      Getting somewhere now - Im getting the list! Just to let you know Im using the plugin Ruby Console Editor to run your scripts and am now viewing the results in the (built in) Ruby Console - I hope this isn't causing any of the issues.
                      I ran the first part of your test and got the following
                      PLAT Carpet Amber FULL Diagonal A.skp
                      PLAT Carpet Amber FULL Diagonal B.skp
                      PLAT Carpet Amber FULL Diagonal C.skp
                      PLAT Carpet Amber FULL Diagonal D.skp
                      "Nil result (no result returned or run failed)"
                      Then I ran the second part and got
                      When I type 'skps' i get this
                      "C:/Users/sam.morris/Documents/TEST COMPS/PLAT Carpet Amber FULL Diagonal A.skpC:/Users/sam.morris/Documents/TEST COMPS/PLAT Carpet Amber FULL Diagonal B.skpC:/Users/sam.morris/Documents/TEST COMPS/PLAT Carpet Amber FULL Diagonal C.skpC:/Users/sam.morris/Documents/TEST COMPS/PLAT Carpet Amber FULL Diagonal D.skp"
                      So Im getting somewhere - the (plugin) Ruby Console Editor wasn't showing me the list so didn't look like anything was happening.
                      I tried copying and pasting some of your code to load the skps but Im a serious Ruby novice so keep getting syntax error messages! Im guessing what I need to do next is run this piece of code
                      But couldn't work out whether in needs to be in any kind of container '{}' or '[]'?
                      Once I have loaded the skps, do I need to past the following into the console at ###
                      pt.x=pt.x+1.m
                      Thanks again
                      SU Pro 2016
                      PC Windows 10
                      16gb RAM
                      • TIGT
                        skps.each{ |skp|defn=defs.load(skp) ****}****
                        Loads the SKPs into the model.
                        The other part is only if you want to add an instance to the model's entities too...
                        • S
                          samyell77
                          Hi TIG,
                          Managed to have another look at this today - afraid Im falling at the last hurdle tho. Have run the code an managed to get them to load into the components browser but can't seem to get the components to place into the model. Once I have run this part of code;
                          skps=[]
                          skps.each{|skp|defn=defs.load(skp);}
                          the components load into the component browser. Can I just check that nothing should be loading into the model window at this point. Not sure whether
                          should actually put each newly loaded component into the model at 0,0,0?
                          I have tried pasting the next piece of code in so that it reads as follows;
                          skps=[]
                          skps.each{|skp|defn=defs.load(skp);tr=Geom::Transformation.new
                          (pt)inst=defs.add_instance(defn, tr)pt.x=pt.x+1.m}
                          When I run this in the (plugin) Ruby Code Editor I get the following from the Ruby Console;
                          Error: #<SyntaxError: (eval):9:in initialize': compile error (eval):9: syntax error, unexpected tIDENTIFIER, expecting '}' (pt)inst=defs.add_instance(defn, tr)pt.x=pt.x+1.m} ^ (eval):9: syntax error, unexpected tIDENTIFIER, expecting '}' (pt)inst=defs.add_instance(defn, tr)pt.x=pt.x+1.m} ^> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/as_plugins/as_rubyeditor/as_rubyeditor.rb:178:in initialize'
                          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/as_plugins/as_rubyeditor/as_rubyeditor.rb:199:in eval' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/as_plugins/as_rubyeditor/as_rubyeditor.rb:178:in initialize'
                          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/as_plugins/as_rubyeditor/as_rubyeditor.rb:199:in `call'
                          Ive tried moving '}' to various different points and have put various bits of code on new lines but still cant seem to find out why this isn't working. Really sorry to trouble you with this again but Im sooo close to getting this working - any chance you can help me get the last bit sorted? Ive attached a screen grab showing the components in the browser but not in the model and also to show how the code is formatted in the Ruby Code Editor. Just want to get the loaded components from the browser into the model starting at 0,0,0 and spaced at 1m increments along the x plane - and am tantalizingly close!
                          Thanks again for all your help ...
                          Sam
                          SU Pro 2016
                          PC Windows 10
                          16gb RAM
                          • TIGT
                            Use a simple
                            skps.each{|skp|defs.load(skp)}
                            which loads the skps into the definitions-list.
                            If you want to place instances of the definitions into the model you need to decide where the go.
                            Piling them all at the origin seems a bit silly?
                            How will you decide where they go ?
                            Let's assume they are added in a line from the origin incrementing in the x by 1m...
                            pt = Geom::Point3d.new(0,0,0)
                            You've just added the definitions and we know how many were added (skps.length), therefore we can get the new ones thus:
                            newdefs = defs.to_a[(defs.length - skps.length)..-1]
                            Now we add the instances to the model.
                            newdefs.each{|defn| tr=Geom::Transformation.new(pt) model.entities.add_instance(defn, tr) pt.x=pt.x+1.m }
                            This shifts 'pt' to the right 1m each time...
                            • S
                              samyell77
                              Hi TIG
                              Im still getting a syntax error on this Im afraid. Below is everything that is listed in the console when i copy and paste the lines of code.
                              #Sketchup::Model:0xcec7dfc
                              #Sketchup::Entities:0xecc7c58
                              #Sketchup::DefinitionList:0xebaa640
                              skps=[]
                              nil
                              skps.each{|skp|defn=defs.load(skp)}
                              ["C:\Users\sam.morris\Documents\TEST COMPS/PLAT Carpet Amber FULL Diagonal A.skp", "C:\Users\sam.morris\Documents\TEST COMPS/PLAT Carpet Amber FULL Diagonal B.skp", "C:\Users\sam.morris\Documents\TEST COMPS/PLAT Carpet Amber FULL Diagonal C.skp", "C:\Users\sam.morris\Documents\TEST COMPS/PLAT Carpet Amber FULL Diagonal D.skp"]
                              Point3d(0, 0, 0)
                              [#Sketchup::ComponentDefinition:0xed92f20, #Sketchup::ComponentDefinition:0xed92e1c, #Sketchup::ComponentDefinition:0xed92dcc, #Sketchup::ComponentDefinition:0xed8aab4]
                              newdefs.each{|defn|tr=Geom::transformation.new(pt)model.entities.add_instance(defn, tr)pt.x=pt.x+1.m}
                              %(#FF0000)[Error: #<SyntaxError: (eval):178: compile error
                              (eval):178: syntax error, unexpected tIDENTIFIER, expecting '}'
                              ...m::transformation.new(pt)model.entities.add_instance(defn, t...
                              ...ities.add_instance(defn, tr)pt.x=pt.x+1.m}
                              (eval):178]
                              Ive copied and pasted every line of code in one by one in the ruby console but keep getting a syntax error when i put this line in
                              All the definitions are have been added, just cant seem to get any instances into the model?
                              Can you shed any light for me - sorry this keeps coming back to you.
                              Sam
                              SU Pro 2016
                              PC Windows 10
                              16gb RAM
                              • TIGT
                                You can't have multi-line blocks in the Ruby Console [expect perhaps on a MAC?].
                                Making it as one line you need ' ;' where the newline would be... so
                                newdefs.each{|defn|tr=Geom;;transformation.new(pt)model.entities.add_instance(defn, tr)pt.x=pt.x+1.m}
                                should become
                                newdefs.each{|defn|tr=Geom;;transformation.new(pt);model.entities.add_instance(defn, tr);pt.x=pt.x+1.m}
                                NOTE this is all in one line but the code-pane 'wraps' it...
                                Then it should work...
                                • S
                                  samyell77
                                  Hi TIG,
                                  Still no dice Im afraid!
                                  %(#FF0000)[skpfolderpath='C:\Users\sam.morris\Documents\TEST COMPS'
                                  #Sketchup::Model:0xca07ab0
                                  #Sketchup::Entities:0xe967bbc
                                  #Sketchup::DefinitionList:0xe84a5a4
                                  skps=[]
                                  nil
                                  Point3d(0, 0, 0)
                                  [#Sketchup::ComponentDefinition:0xe6e0704, #Sketchup::ComponentDefinition:0xe6e0614, #Sketchup::ComponentDefinition:0xe6e05d8, #Sketchup::ComponentDefinition:0xe6d9634]
                                  newdefs.each{|defn|tr=Geom::transformation.new(pt);model.entities.add_instance(defn, tr)pt.x=pt.x+1.m}
                                  (eval):178]
                                  Am I missing a step - am working on PC and am pasting each line into ruby console one at a time... but still get this unexpected tIDENTIFIER error? Im afraid I can't troubleshoot this at all with my very limited ruby knowledge. Any ideas?
                                  SU Pro 2016
                                  PC Windows 10
                                  16gb RAM
                                  • S
                                    samyell77
                                    [hr]just spotted that I was missing the ';' in this line just before 'pt.x' but have added it in, re-run and am now getting a different error (have highlighted the code in red this time and the result from the ruby console in blue...)
                                    skpfolderpath='C:\Users\sam.morris\Documents\TEST COMPS';model=Sketchup.active_model;ents=model.active_entities;defs=model.definitions;skps=[;Dir.foreach(skpfolderpath){|f|skps << File.join(skpfolderpath, f) if File.extname(f).downcase==".skp"};skps.each{|skp|defn=defs.load(skp)}]
                                    Point3d(0, 0, 0)
                                    [#Sketchup::ComponentDefinition:0xeb0e344, #Sketchup::ComponentDefinition:0xeb0e254, #Sketchup::ComponentDefinition:0xeb0e218, #Sketchup::ComponentDefinition:0xeb06270]
                                    newdefs.each{|defn|tr=Geom::transformation.new(pt);model.entities.add_instance(defn, tr);pt.x=pt.x+1.m}
                                    %(#0000BF)[Error: #<NoMethodError: undefined method transformation' for Geom:Module> (eval):181 (eval):181:in each'
                                    (eval):181]
                                    SU Pro 2016
                                    PC Windows 10
                                    16gb RAM
                                    • S
                                      samyell77
                                      Also added ';' to all the lines of code to make complete blocks so I could paste a whole block in in one go rather than line by line - hope this is ok...
                                      SU Pro 2016
                                      PC Windows 10
                                      16gb RAM
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Another cap error on the same line:
                                        should be:
                                        newdefs.each{|defn|tr=Geom;;Transformation.new(pt);model.entities.add_instance(defn, tr);pt.x=pt.x+1.m}
                                        class (and module,) identifiers are actually constants so start with a capital character.
                                        I'm not here much anymore.
                                        • TIGT
                                          Thanks Dan, I missed the [tT]ransformation typo in his code I copy/pasted..... πŸ˜’
                                          The error messages are pretty good at telling you what is wrong πŸ˜‰
                                          • S
                                            samyell77
                                            TIG, Dan,
                                            Yee haaa! It works! Thank you both so much - TIG, thanks for being patient with a ruby luddite and Dan, thanks for finding the final missing piece of the puzzle. You have both been a huge help.
                                            SU Pro 2016
                                            PC Windows 10
                                            16gb RAM
                                            • 1 / 2
