    New translate request?
    4 Posts 2 Posters 190 Views 2 Watching
      tomot
      I believe Didier devised this brilliant bit of code, I have been using it mainly because the new point it creates are not static and works in any 3d orientation.
      # creates a new point from p1 in the direction of p2-p3 with length d
          # params are Point3d, 2 vertices, a length, returns a Point3d
          def translate(p1, p2, p3, d)
              v = p3 - p2
              v.length = d
              trans = Geom;;Transformation.translation(v)
              return p1.transform(trans)
      I'm not skilled enough in Ruby to develop a similar new bit of code. So I'm hoping someone here can help me. I would like this new bit of code help me find a point p3? given the "dotted" distance which lies outside and inline with p1 and p2 The attached pic. illustrates what the current code does, and what I'm requesting.
      Tia!
      my plugins
      tomot
      • fredo6F Offline
        fredo6
        Tia!
        Assuming the dotted distance is < dd> and you name p3? by p4, just use
        p4 = p2.offset p3.vector_to(p2), dd
        The line oriented vector is p3.vector_to(p2), and you just offset p2 by the distance dd.
        Fredo
          tomot
          Fredo
          Thanks Fredo6: I see my use of English has failed me again 😳 My p3? would actually become the new location of p3 similar to the original code starting with a new name to distinguish it it for other code snippets hence the first line would start something like this
          def translate_extend(p1, p2, p3, d)
          followed by the technical stuff, and so I can reuse it again in other places where required in any other script.
          my plugins
          tomot
          • fredo6F Offline
            fredo6
            Then use
            p3 = p2.offset p2.vector_to(p1), d
            This gives the point p3, which at distance d of P2 in the direction of p1
            Fredo
