    Finding new rotated 3d coordinate points?
    4 Posts 3 Posters 303 Views 3 Watching
      tomot
      I have a defined face which is made up of four 3d points such as:
      base = entities.add_face(pt1, pt2, pt3, pt4)
      I now rotate that face 45 degrees by:
      t = Geom::Transformation.rotation(pt0,Geom::Vector3d.new(0,0,1), 45.degrees) group.move!(t)
      The original face has now been rotated about a some point pt0. I can determine using math the new pt1new, pt2new, pt3new, pt4new co-ordinates of that rotated face, but is there a more direct and less tedious method I'm not aware that will allow me to determine those new 3d points?
      TIA!
      my plugins
      tomot
      • Dan RathbunD Offline
        Dan Rathbun
        I think there was a recent topic on this...
        lets see, perhaps:
        grpdefn = grp.entities.parent
        pts = []
        grpdefn.entities.each {|e|
          if e.is_a?(Sketchup;;Face)
            e.vertices.each{|v| pts << v.postion }
        pts.uniq!
        I'm not here much anymore.
          Dan Rathbun
          Also if the face is the only thing in the group, you may use group.local_bounds
            Using
            group.move!(t)
            will miss the 'undo stack' [typically used in animations], whereas using
            group.transform!(t)
            won't.
            You can apply a transformation to a 3d point [and vector] too, to make a new reference use
            pt1new=pt1.transform(t)
            or
            pt1.transform!(t)
            to 'reuse' pt1 which is '!' changed to its matching vertex's current value
            https://developers.google.com/sketchup/docs/ourdoc/point3d#transform
