Naming components
I'm having a problem with a seemingly simple task. how can I add both a Name and Defintion Name to a component that contains subcomponents?
I can add both to an instance of the subcomponents without a problem but I can only manage to add the Defintion Name to the parent component.
I've read and searched but can't find a solution.
def=model.definitions.add @name + " (test def)" entities=def.entities ins=entities.add_instance @def_test, [0, 0, 0] name=ins.name=@name + " (test ins)"Thanks,
Frank -
I can add both to an instance of the subcomponents without a problem but I can only manage to add the Definition Name to the parent component.
> def=model.definitions.add @name + " (test def)" > entities=def.entities > > ins=entities.add_instance @def_test, [0, 0, 0] > name=ins.name=@name + " (test ins)" >Thanks,
Frank
You can't use 'def' as a reference - it's reserved for 'methods', try 'defn' instead.defn=model.definitions.add(@name + " (test def)") tr=Geom;;Transformation.new() ins=defn.entities.add_instance(@def_test, tr) name=ins.name=@name + " (test ins)"Should work ??
You can assign a value to the
nameattribute to a particularSketchup::ComponentDefinitionas many times as you like, but after the first time, you will be re-assigning a new value.Keep in mind that, Rubywise, when you say definition, you really are talking about an instance of the
Sketchup::ComponentDefinitionclass.And.. when you say, instance, we are talking about an instance of the
Sketchup::ComponentInstanceclass.BOTH of these two class objects have an instance method, that allows assigning a (usually
String) value, to an instance variable.
The method identifiers, are the same (and likely the attributes, ie, instance variables,) "name".NOW... you may be a bit confused. Every
Sketchup::ComponentInstanceinstance, has aSketchup::ComponentDefinitioninstance, that describes it's properties, and if it is not unique, holds a list of all it's other siblings in the model.OK.. you do not attach OTHER
Sketchup::ComponentDefinitioninstances to / beneath / inside of anotherSketchup::ComponentDefinition. Instead, you attachSketchup::ComponentInstanceinstances, (who are described bySketchup::ComponentDefinitioninstances,) to ANOTHERSketchup::ComponentDefinitioninstance, that has nested components.SO.. the actual nested objects... are
Sketchup::ComponentInstanceinstances, neverSketchup::ComponentDefinitioninstances.Think of a
Sketchup::ComponentDefinitioninstance as being a specification, and all theSketchup::ComponentInstanceinstances OF IT, as being the articles built TO the specification.Lastly... all the
Sketchup::ComponentDefinitioninstances, are kept at the model level, (all in one drawer of specifications, so to speak.) Accessed via themodel.definitions()method. -
And you should be using an editor like Notepad++ that has syntax highlighting, to avoid attempting to use keywords as variable names.
http://notepad-plus-plus.org/download/
see: [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=39783:2pgebma3][Info] Notepad++ : Tip, Tricks & Plugins[/url:2pgebma3]
Thanks for the replies.
Sorry for using def as a reference, I'm not using that in my plugin code it was just as an example... though I didn't know not to use it... learn something new everyday.
I got used to komodo edit for some reason even though seems like Notepad ++ is what most use.Now, that being said... Dan you're 100% correct I'm totally confused
. And I'll have to reread your post a few times to get it straight, thanks for taking the time to explain the differences in detail.TIG, using your code I get the same result as I am now. Which is my parent component has a definition name but no name and the child component has both. I know I'm probably not explain what I'm trying to do properly since as already stated I'm confused.
Here's something I found that resembles what I want to do other then I'm not working with groups...
From a post by ThomThom, here...
http://forums.sketchucation.com/viewtopic.php?f=180&t=23567group = model.active_entities.add_group(sel) name = model.definitions.unique_name(input[0]) # We set the name we will see in the Entities window. group.name = name # We set the definition name as well. If you convert the group to a component, this is the # name it will get. group.entities.parent.name = nameAnd also from TIG, here...
http://forums.sketchucation.com/viewtopic.php?f=180&t=23311instance=group.to_component definition=instance.definition definition.name="My Definition's Name" instance.name="My Instance's Name"Hope that helps making what I'm trying to do clearer...
Thanks,
Frank -
The code I offered you was simply a corrected version of yours.
The code makes a new definition ['defn'] assigning it a new name [all definitions must have a unique name].
The code then adds an instance of another preexisting component [again that definition must have a unique name of its own] into the entities of 'defn'.
When that the instance is added it has no name [the default].
The code then gives that instance a name.
It also assigns a variable 'name', but does nothing with it.
The code then stops.If you were then to add an instance of 'defn' it would obviously display that component's definitions name [all instances of that definition will!]... However, an instance will not have a name, because by default a new instance does not have a name.
Of course you could give that instance any name you like... perhaps using 'name'...
Ok so far I understand that logic and I'm aslo able to put it onto practice... except for the part I highligthed in bold... which correctly explains what I'm not able to do. I don't get where I should add the 'name' part. the only way I can think of is by
defn_new=entities.add_instance defn, [0, 0, 0]but I get a double occurance error. And everything else I've tried will change the defintion name and not add an instance name.
Perhaps it's in how I add the instance of defn to the model that is the problem(I hope I'm using the correct term, still a little confused)?...
status=model.place_component(defn) -
dins=model.active_entities.add_instance(defn, tr) dins.name=name
Themodel.place_component(defn)is like picking 'defn' off the Component-Browser.
You'll get no 'reference' to it this way - so naming it is difficult - because it'd be the only instancedefn.instances[0]would refer to it, BUT the 'place_component' will break your code when it's invoked - a convoluted observer set up might work BUT there are other easier ways...
Useadd_instanceand then if you want the instance [dins] to be movable thereafter you can write your code as a 'Tool' class and then have the transformation ofdinreset dynamically to always be at the cursor's point, and when you left-click the mouse it'd setdins's transformation to be at the clicked point...
BUT perhaps that is too complex for now
I knew that model.place_component was too good to be true!
@tig said:
Use
Ok, I have no idea what all that means but I'm game to learn it! Could you point me in the right direction? Maye a plugin that already does something similiar or a code snippet to get me started?
Thanks for the help TIG!
@frankn said:
Sorry for using
defas a reference, I'm not using that in my plugin code it was just as an example... though I didn't know not to use it... learn something new everyday.
They are called "reserved" keywords for good reason. Their misuse will confuse the poop out of the Ruby interpreter.
Here's a URL bookmark for ya':
Well as long as it has syntax highlighting for Ruby, that shows keywords, and classes in a different color than user defined variables... it's OK. I also know some people are partial to NetBeans.
That's what syntax highlighting is all about. Helping you to not make those kind of mistakes.
Thanks for the link Dan... that's the kind of info that seems trivial till you run into a problem.
Yeah Komodo does all that good stuff plus the pro version does a bunch of other stuff and even debugging for ruby, I think. But I tried it and it had too many bells and whistles for a newbie like me and was confusing!
Register LoginAdvertisement
