    Photo Match
    3 Posts 2 Posters 262 Views 2 Watching
    • A
      augoneine
      I have a simple question about Photo Match: is it possible to view the model I've constructed over the base photograph, and then export it as a 2D graphic? At the moment I can only seem to have a view of the model "ghosted in" behind the photo, but in tutorials and such I have seen the constructed model viewed in the foreground (I'm guessing this may be the case in older versions of Sketch Up and may not be possible now?). I am using SkethUp Pro 8, with Snow Leopard, if that information is useful. Any help is appreciated.
      • GaieusG
        Go to your Window > Styles dialog and there, under the "In model" folder (the small house icon), Edit tab, either uncheck or pull the foreground photo to the extreme left.
        https://lh5.googleusercontent.com/-YtaaisSOGgc/TzQ4NadTyWI/AAAAAAAAHwQ/CoBZ-lCdPtw/s458/MatchPhotoSettings.png
        • A
          augoneine
          Thank you, thank you, thank you.
