    [Tutorial] Modeling a Space Frame
    25 Posts 14 Posters 10.5k Views 14 Watching
    • boofredlayB Offline
      boofredlay
      For those who have not looked at the space frame thread here I thought I would post this in the Tutorial Forum as it has proved helpful to kelvin and others.
      [flash=853,505:1fl5m2u3]http://www.youtube.com/v/8197whwxM2Y&fs=1[/flash:1fl5m2u3]
      • soloS Offline
        solo
        Doh!!!
        I just learned something new, almost embarrassed to say, I never knew about the additional setting with JPP, damn, if I knew this before I could've modeled even faster.
        Thanks Eric.
        Slaps head.
        http://www.solos-art.com
        • tademaT Offline
          tadema
          Eric,
          I could watch your videos all day long. You have a great way of modeling.
          John
          • StinkieS Offline
            Stinkie
            Yeah. 😲
              boofredlay
              Well thanks again guys. Sometimes I surprise myself.
              • david_hD Offline
                david_h
                Once again. . .you are engineered to amaze.
                • mitcorbM Offline
                  mitcorb
                  @Boofredlay: I suggest a warning label on all of your tutorials "Caution to learners: watching these tutorials may cause one of two things--it may stunt your growth, or it will inspire your inner artist. 💚
                    boofredlay
                    😄 Thanks.
                      Late
                      Great and inspiring tutorial. But I'm totally hobbyist so how you moved the sphere from it's center point?
                        boofredlay
                        When you use the sphere plugin, placement is at the center bottom of the sphere.
                        #1 in my example image.
                        Then get the move tool, click on the midpoint of one of the outside lines (midpoint on the sphere). I turned on the x-ray view style for this step. Start moving it in the blue direction, hold shift then click the reference point where you want the sphere to "land".
                        #2 in my example image.
                          Late
                          Thanks. It's always fun to learn new things.
                          • utilerU Offline
                            utiler
                            @solo said:
                            Doh!!!
                            Thanks Eric.
                            Slaps head.
                            Nether did I, Pete!!!
                            BTW how do you upload a youtube video to here? And what software are you using to record?
                            Well done, Boo. Love your work!
                            Just Curious...
                              boofredlay
                              Thanks Andrew.
                              I use Hypercam2
                              http://www.hyperionics.com/hc/
                              Make sure you change the keyboard shortcuts (Hot Keys) because they can interfere with your SU ones and mess up your video. I found that out the hard way.
                              After taking the video I used Windows Live Movie Maker to add text and edit it. Then uploaded to Youtube.
                              Both Hypercam and WLMM are free.
                              Attaching the Youtube to your post is best explained in Miguel's post here:
                              http://forums.sketchucation.com/viewtopic.php?p=144086#p144086
                              • utilerU Offline
                                utiler
                                Cheers, Boo
                                Just Curious...
                                • mitcorbM Offline
                                  mitcorb
                                  You think maybe Hypercam 2 will work on Win 7? The info stops at xp?
                                    boofredlay
                                    Yep. I use it at home and work on Win7.
                                    • mitcorbM Offline
                                      mitcorb
                                      Ok, thanks.
                                        Cool tut ☀
                                        Maybe you can use the Guides Tool by ThomThom for put the Spheres more quickly?
                                        Image by guanjin
                                        http://forums.sketchucation.com/download/file.php?id=84409
                                        • usenU Offline
                                          usen
                                          Thanks. 👍
                                          http://www.sketchupturkiye.com/
                                            shahriyar
                                            Thanks Again
                                            • 1 / 2
