    [Tutorial] Modeling a Space Frame
    25 Posts 14 Posters 11.3k Views 14 Watching
    • soloS
      Doh!!!
      I just learned something new, almost embarrassed to say, I never knew about the additional setting with JPP, damn, if I knew this before I could've modeled even faster.
      Thanks Eric.
      Slaps head.
      • tademaT
        tadema
        Eric,
        I could watch your videos all day long. You have a great way of modeling.
        John
        • StinkieS
          Stinkie
          Yeah. 😲
          • boofredlayB
            boofredlay
            Well thanks again guys. Sometimes I surprise myself.
            • david_hD
              david_h
              Once again. . .you are engineered to amaze.
              • mitcorbM
                mitcorb
                @Boofredlay: I suggest a warning label on all of your tutorials "Caution to learners: watching these tutorials may cause one of two things--it may stunt your growth, or it will inspire your inner artist. 💚
                • boofredlayB
                  boofredlay
                  😄 Thanks.
                  • L
                    Late
                    Great and inspiring tutorial. But I'm totally hobbyist so how you moved the sphere from it's center point?
                    • boofredlayB
                      boofredlay
                      When you use the sphere plugin, placement is at the center bottom of the sphere.
                      #1 in my example image.
                      Then get the move tool, click on the midpoint of one of the outside lines (midpoint on the sphere). I turned on the x-ray view style for this step. Start moving it in the blue direction, hold shift then click the reference point where you want the sphere to "land".
                      #2 in my example image.
                      • L
                        Late
                        Thanks. It's always fun to learn new things.
                        • utilerU
                          utiler
                          @solo said:
                          Doh!!!
                          Thanks Eric.
                          Slaps head.
                          Nether did I, Pete!!!
                          BTW how do you upload a youtube video to here? And what software are you using to record?
                          Well done, Boo. Love your work!
                          Just Curious...
                          • boofredlayB
                            boofredlay
                            Thanks Andrew.
                            I use Hypercam2
                            http://www.hyperionics.com/hc/
                            Make sure you change the keyboard shortcuts (Hot Keys) because they can interfere with your SU ones and mess up your video. I found that out the hard way.
                            After taking the video I used Windows Live Movie Maker to add text and edit it. Then uploaded to Youtube.
                            Both Hypercam and WLMM are free.
                            Attaching the Youtube to your post is best explained in Miguel's post here:
                            http://forums.sketchucation.com/viewtopic.php?p=144086#p144086
                            • utilerU
                              utiler
                              Cheers, Boo
                              Just Curious...
                              • mitcorbM
                                mitcorb
                                You think maybe Hypercam 2 will work on Win 7? The info stops at xp?
                                • boofredlayB
                                  boofredlay
                                  Yep. I use it at home and work on Win7.
                                  • mitcorbM
                                    mitcorb
                                    Ok, thanks.
                                      Cool tut ☀
                                      Maybe you can use the Guides Tool by ThomThom for put the Spheres more quickly?
                                      Image by guanjin
                                      http://forums.sketchucation.com/download/file.php?id=84409
                                      • usenU
                                        usen
                                        Thanks. 👍
                                        http://www.sketchupturkiye.com/
                                          shahriyar
                                          Thanks Again
                                          • brookefoxB
                                            brookefox
                                            Thank you, Eric.
                                            Now if we could only get the size and res of embedded vids jacked up so we can see what the plugin settings are that are being used (JPP in this case). Alas, at present, there seems not to be a way.
                                            ~ Brooke
