    Need help with Curved Form
    8 Posts 4 Posters 602 Views 4 Watching
      duralex
      Hello world!
      Can help me with some advice how to do this form from the picture, I don't want the form to be sliced, just solid. I am tryin from 3 days but the results are not good.
      http://www.designboom.com/contest/files/_radiator_03.jpg
      Any advice is apreciated.
        Hi Adrian,
        Since you have fairly good section slices drawn at the top left, you could trace those and at the end skin those slices. There are good plugins for both. For the curvy contours, here is a good bezier plugin:
        http://forums.sketchucation.com/viewtopic.php?t=13563
        and for the final skinning, this would be fine:
        http://forums.sketchucation.com/viewtopic.php?t=28586
        I would be modelling it at a bigger scale to avoid incidental, small faces (which SU often has issues with) and scale it down at the end when done.
          duralex
          Thank's a lot!
          Back to work.......
          • dukejazzD Offline
            dukejazz
            Two side mask of a flat free form texture.
            [Tutorial] Making a jpg mask
            http://forums.sketchucation.com/viewtopic.php?f=18&t=42162
            With sandbox tool to press in the concave depressions
            • gillesG Offline
              gilles
              Once you got the shape try Tig Slicer.
              http://forums.sketchucation.com/viewtopic.php?t=42267#p374969
                duralex
                The problem is not to slice the model ..... is to obtain that organic form ...
                Still working ... πŸŽ‰
                  duralex
                  I'm not 100% satisfied but is an alternative.
                  Thanks for help to all.
                    Well, satisfied or not, you know have the technique I guess (looks good although certainly not exactlythe other shape)
