    Sketchup Plugin Debugger
    6 Posts 5 Posters 2.6k Views 5 Watching
      brian_concannon
      I have developed a debugging tool for Sketchup plugins. It allows conditional watches and breakpoints and examining/setting variables and tracing through the code and seeing variable values changing.
      I am posting the user guide below, and a zip file with the required files and all source code (Ruby and VB.net).
      Enjoy. All free for you.
      Debugger User Guide
      deployment package
        Is it possible to make it output to an external app like DebugView? SU's Ruby Console slows down very quickly as it's being filled up.
        • Dan RathbunD Offline
          Dan Rathbun
          Is this different than the "Debuggifier" you posted previously ??
          I'm not here much anymore.
            jefftrull
            I gave this a try today, with no luck... The instructions say to run "deploy\setup.exe" but there is no such directory. There is a "publish\setup.exe", so I ran that. At the end of the install process it prompted me to supply a pair of filenames to process (input and output, I presume) so I did. The resulting ruby script was identical to the input, except for changes in formatting - in other words, only whitespace differences. No special debug commands were added that I could see, and indeed, when I ran my script it crashed as usual, with no helpful debug popups etc. Also, the documentation refers to a "Debuggified" plugin, but I see no evidence that this was installed. Is it something I am supposed to manually copy?
            If anyone has used this successfully, I would like to hear your install/usage procedure.
            Thanks,
            Jeff
            • Didier BurD Offline
              Didier Bur
              Below are the last lines of face2face.rb, included with the package:
              # Add a menu choice for creating extrusion
                unless file_loaded?('Face2Face.rb')
                  file_loaded('Face2Face.rb')
                  $submenu ? (organizer = $submenu) ; (organizer = UI.menu('Plugins'))
                  organizer.add_item('Extrude Face2Face') { MF2F.tool }
                  organizer.add_item('Face2Face Parameters') { MF2F.parameterstool }
              What's this mess ? Is this file really necessary ?
              Please provide installation instructions...
              DB
                Dan Rathbun
                It is for Smustard Menu Organizer
