    Repeat Last command??
    25 Posts 7 Posters 7.7k Views 7 Watching
      No worries. I suppose it doesn't work if you select more than one face because they might have different orientations and then which face would SketchUp use as the reference face? It might make the magic smoke come out of the processor. 😲
      • mitcorbM Offline
        mitcorb
        I guess he didn't see my suggestion above.
          jpalm32
          Yes I did Tim, thank you.
          Going back & forth while working.
          • Dan RathbunD Offline
            Dan Rathbun
            ThomThom also authored the Selection Toys plugin.
            You NEED to get that. It allows you to get selection sets, based on search criteria, and apply filters.
            Now, ALSO built into Sketchup... select ONE face, right-click it, click "Select >" on the popup, and choose "ALL on the same Layer" (or Material which is likely to be nil as a default.)
            Now you have a selection set whose members can be out of the viewport.
            (You could always Zoom Extents, also before selecting.)
            Here's another plugin by Didier Bur: Automatic Face Reverser
            Otherwise.. go to Plugins Index and use your browser's find function to look for buzzwords (Reverse, Face, etc.)
            I'm not here much anymore.
            • Didier BurD Offline
              Didier Bur
              Not to mention FrontFace by Tomasz Marek, which is my favorite !
              Here: http://rhin.crai.archi.fr/rld/plugin_details.php?id=154
              DB
              • 2 / 2
