    Image on curved surface
    5 Posts 3 Posters 378 Views 3 Watching
      tspco
      I have been wanting to make a custom coffee cup with a logo on it.
      I tried to project an image onto it, which sort of worked. I need to tweak the size of the image to project, to get it right after about 10 tries I gave up.
      Is there a plugin that will do this?
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • mitcorbM Offline
        mitcorb
        This may not be your answer, but I put in "image projection" in the search box at the top of the screen and got this: http://forums.sketchucation.com/viewtopic.php?f=79&t=41603&p=368618&hilit=image+projection#p368618
        Edit: you will see other posts and threads with those terms highlighted if you do the search. Gaieus was especially helpful on this matter.
          If your coffee cup is made out of quads you can use QuadFace Tools to map the mesh: http://forums.sketchucation.com/viewtopic.php?t=39442#p348501
          • mitcorbM Offline
            mitcorb
            Up kind of late aren't you, T? Or is it early?
              Late - just got home. And I haven't even been out on the town... 😕 My brain is trying to tow my body to bed.
