    Anchor point when pasting
    24 Posts 6 Posters 5.6k Views 6 Watching
      sketchy
      jeez, sorry to not be a forum regular and be aware of the proper etiquette. I set up membership a long time ago and had no idea the version I used was even in my profile. Since you pointed it out I see it and have updated it.
      I am sorry you feel like you "wasted" your time. I thought this would be a good place to post a question about something I was having trouble with to people who felt like helping to whatever degree they were interested. That seemed like the case a while ago when I was using Sketchup and these forums more. I don't feel like I wasted my time, I learn from trial and error and now I know more than when I started about sketchup and this forum.
        mwm5053
        No wasted time that's a very good explanation of cutting a group I've forgot to up date my profile as well. I was curious why did you use groups rather than components and why did you not use sections to do that. May help me in doing that.
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
          mwm5053
          Where in New Mexico. Are you from or living.
          2011 iMac
          V2 Twilight
            sketchy
            @mwm: In my workflow I group/component everything that is a physically distinct object for the most part. I feel like it makes the model behave more like a real world object and is easier to edit. I do not use any geometry that is not in a group or component because it always seems to create way too many problems when I move or alter things. I use components for anything that is identical or symmetrical so I only need to modify one of them or one side of it. In this case each stud is unique so I use groups. This way if I duplicate a stud and alter one of them later they both don't change. I use layers for assemblies that are related (wall framing, roof framing, wall skin, windows and doors etc)
            I use sections seldomly since SU doesn't render solids I find them to be of limited use for my work. In this case I am modeling the walls due to the complexity of the angles involved. I have a 5 man crew at the moment and If I can give them a plan with the angles and lengths called out it makes the work much quicker.
            I am in Taos
            • 2 / 2
