    Podium V2 interior
    72 Posts 24 Posters 10.9k Views 24 Watching
    • N Offline
      notareal
      New one. Tad too gloomy, me thinks...
      I like the atmosphere!
      • StinkieS Offline
        Stinkie
        I could do a version with Thea ... if there were interior rendering presets available to pick apart. πŸ’š
        • N Offline
          notareal
          For biased rendering? I'd start from "04. Final Gathering" preset and improve quality if needed. Or perhaps new Adaptive (AMC) from interactive renderer, as it's fairly fast if bias is set high (also enable caustics for better light).
          • StinkieS Offline
            Stinkie
            Hm, I'll try that. Thea's biased engine is still somewhat of a mystery to me. πŸ˜„
            • N Offline
              notareal
              You could try this Adaptive (BSD) -preset. Save in "C:\ProgramData\Thea Render\Presets" in Win7. If it feels too slow, downgrade settings towards "04. Final Gathering" -preset. Also you can disable or tune down "Ambient Occlusion" under Render | Biased RT, if it disturbs.
              Also some material tuning may be needed. Under material general, set Perceptual Level(%) to 10,000 if your material has textures (higher will give better quality but difference is small as textures do hide imperfections) also if you have glossy materials you can set they Tracing Depth to 8-12 (if some black areas appear as result of too low tracing depth).
              Final Gathering Interior.zip
              • soloS Offline
                solo
                Tom
                Can you share the model? I'd like to play with Thea's biased engine to see what speeds I can get...when I get the time.
                http://www.solos-art.com
                • StinkieS Offline
                  Stinkie
                  Pentti -thanks!
                  Pete -of course. Tomorrow, after I've dropped of Wee Satan at school. I'll have to take the wall and floor textures out, though -they're from the non-free section of the Podium Component Browser. Did I notice familiar looking plants in there, btw?
                  In the meantime, here's a version with the lamp switched on.
                  • stefanqS Offline
                    stefanq
                    Looks fantastic Tom. As for the "art on the wall" you can use your own prints.
                    • StinkieS Offline
                      Stinkie
                      I tried that. Looked "meh". πŸ˜„ So ... it's done. 😎
                      • soloS Offline
                        solo
                        Tom,
                        Firstly thanks for pm'ing me the .skp, Notareal sent me the link to the original model here: http://www.3dallusions.com/Site/Vault/ArchModels/Kitchen_SKP.zip which by the way is horrible as it is totally out of proportion, off axis and spends way more poly's than it needs, yours is nicely optimised...thank you.
                        On opening yours I noticed your setup, which I believe is way more relevant than any render preset/setup. You have used L.E.M's in order to mimic exterior light as well as one to give light behind the camera.
                        I was instantly reminded of my days with Podium 1 and remember this being the best way to get soft shadows and good even lighting, however I wondered if this was the fastest way (I cannot remember) did or does LEM's come at a speed cost?
                        Does Podium 2 have HDRI support? as I was wondering if deleting the exterior LEM and using Image based lightning would not be faster with even better soft lighting?
                        I'm assuming the LEM behind the camera is to assist and give some light volume as without it all surfaces facing camera would be black, however I am wondering if there was a way of using ISO, shutter speed and f-number settings to enhance lighting without the need for the LEM?
                        What my rambling is about is the setup of scene may actually be just as if not more important than the actual render settings.
                        • david_hD Offline
                          david_h
                          On second thought. . .I like it this way. It has a very monastic feel to it. A sort of hypo-Tech Austerity that I find appealing. I think putting a big Andy Warhol or worse a Patrick Nagel 🀒 on the wall would be a bit of a cliche.
                          • michaliszissiouM Offline
                            michaliszissiou
                            If two chairs and two apples, then loneliness could be more obvious. 😎
                            Three chairs? three apples? We all are Stanley Kubrick's funs, aren't we?
                            This is a "strong" image. Well done.
                            It's the Ps work that I don't like much. A fake-volumetric effect could turn the scene to a more dramatical way.
                              Who lives here ? Mystery is complete! πŸ˜„
                              • marked001M Offline
                                marked001
                                beautiful stuff!
                                http://www.revision21vis.com
                                instagram: revi21on
                                • StinkieS Offline
                                  Stinkie
                                  Thanks, guys.
                                  Michalis -de gustibus. Still, good idea. πŸ’š
                                  They did use to slow down rendering a lot, yes. But not anymore: nowadays the speed hit, if any, is negligible.
                                  No. However, you can use the SU sky to light your scene -hence you can choose colors on the fly. Turn off SU shadows, and you've got nice soft lighting. Not quite the same thing, admittedly, but it's easy, and as you know that's what Podium is about.
                                  No. No such settings. I would've added the fill light using any other renderer, though.
                                  The setup is important, obviously. Lighing can make or kill a render. The render preset I used did contribute to the quality of the image, though. More photons, better AA and more blur samples than the stock presets. I also rendered big (5000 x 2694) and then downsampled in Photoshop to further improve the AA. Which, given Podium's speed (36 mins for the 5000 x 2694 image), is a totally viable approach.
                                  • soloS Offline
                                    solo
                                    Your last point is interesting and one I have heard and even used from time to time, render large and reduce in post editing.
                                    Have you tested what the time would be to render correct size with higher settings (better AA, etc) in comparison? Just wondering if there is a speed advantage or a quality advantage doing it larger.
                                    • StinkieS Offline
                                      Stinkie
                                      No, I haven't. AA settings are contained within Podium's render presets. I find it more convenient to render large and downsample than to open up the preset I'm using, edit it etc. Also, altering AA settings, test rendering, altering AA settings again ... can be quite time consuming, and it's a process I'm not always in the mood for.
                                      The next version of Podium will give more control over AA via the UI, I believe. Per material AA, or something.
                                      (...) Patrick Nagel 🀒 (...)
                                      I had to look that one up. Ew. 😲
                                      • bigstickB Offline
                                        bigstick
                                        @kais said:
                                        nice rendering but 53 mins. is too much
                                        now in Lumion 2 you can do it less than 53 sec
                                        Yeah, but the quality won't be the slightest bit comparable. I can make an omelette in around 60 seconds, but I wouldn't like to eat it!
                                        I've seen what Lumion does, I've seen what all the render engines can do. They all have their benefits and drawbacks. Lumion's main benefit is speed, its main drawback is quality. Yes, I'm pretty sure you'll disagree but you'll be wrong - certainly as far as Podium is concerned. πŸ˜„
                                        • david_hD Offline
                                          david_h
                                          Yeah .. .Pretty disgusting. that would turn your very elegant modernist expression into a cheesy bachelor pad. The only thing missing would be the hot tub and the gold medallions πŸ’š
                                          • soloS Offline
                                            solo
                                            Patrick Nagel is 30 years too late, it may have worked in the 80's with your Chinese themed black and white shellacked room but today it's just cheesy.
                                            Remember these 80's gems? 🀒
                                            http://27.media.tumblr.com/tumblr_lpqicoDSup1qcygcoo1_500.jpg
                                            Looks like his rubbish
                                            • 3 / 4
