    UV Mapping on curve surfaces
    2 Posts 2 Posters 663 Views 2 Watching
    • P Offline
      Philw
      I was looking to see if there is a UV Map plug-in for SKU that would help work with maps on curved surfaces and so far I have not seen any out there. Are there any or what is the best ways to move maps on curve surfaces? I’ve done projected mapping in the past, but it would be better if I could move maps like you can on a flat surface.
        If your surface can be made into Quads compatible with QuadFace Tools - you can use its UV mapping features: http://forums.sketchucation.com/viewtopic.php?t=39442
        Can you provide more info about your surface? How you generate them for instance? (Fredo's Curviloft let you generate QuadFace Tools compatible quads. So does some of TIGs plugins.)
        Screenshots or sample models of what you are dealing with will help us provide a good answer.
