    Group the selected entities and give them a name[Solved]
    5 Posts 4 Posters 382 Views 4 Watching
    • N
      niccah
      I want to automate following event with a script:
      I group the selected entities, right click: "Elementinformation" and enter a name like "result"...
      So, that's what I already have:
      model = Sketchup.active_model
      selection = model.selection # all the selected entities
      Now I want to add a group, give them a name and add "selection" to the group:
      group = model.add_group
      group.name = "result"
      group.entities. ... (?)
      How can I add the "selection" to that group? It tried a lot, but without success 😞
      Do you have a tip what can I do?
      Thanks a lot for your help!
      • Dan RathbunD
        Dan Rathbun
        In the index for [Code Snippets] by Subject there is this entry:
        Copy selection to new group?
        I'm not here much anymore.
        • N
          niccah
          absolutely perfect! That's it!
          Thanks a lot!
          Just for other interested people:
          selection = model.selection.to_a
          group = model.active_entities.add_group(selection)
          • mitcorbM
            mitcorb
            Just out of curiosity, is there any significance in the white space between "...to_a" and "group=model.active......"?
            • TIGT
              Nothing!
              Just to make reading it easier ?
              Note that gp=some_entities.add_group(some_stuff)
              is ONLY successful if all of the some_stuff entities are in the some_entities context AND it's the active_entities: otherwise you'll Bugsplat!
              So it's fine when you are adding a selection to a group in the same entities - as to select them they must all be in the same [active] entities context and you make the new group in that context too.
              Just be wary of grouping groups and adding things that are in one context into another context - to do that IS possible but involves either complex 'cloning' of geometry OR getting the definition of groups/instances and repeating their instances [temporarily] in the new context before erasing the original one[s]...
