Why are guides appearing?
I'm using Layout 2 and SketchUp 7. When I import my SU model into Layout and select a view in which guides are turned off in SU, the guides appear in Layout. How can I suppress them? Thanks.
I would upgrade first to Layout 3. Much more stable. In your specific case, you may have a differents style selected in layout from that saved in the model. I would check that first. If that doesn't work, I highly recommend doing the upgrade.
Thanks, Sonder. Do you know if there's a charge for upgrading? I'm not using any styles, and the default Engineering and Design styles don't affect the guides.
I can't remember. I believe the 7-8 upgrade may have been free. If not, I think it the last upgrade cost was only something like $90.
I would double check that the style you have selected in LO is the same as the style selected in SU. Some styles do show axis and guides.
The style syncing seems to have been the problem. Upgraded anyway. Thanks.
Register LoginAdvertisement
