    Import CSV to extract values
    7 Posts 4 Posters 1.7k Views 4 Watching
    • K Offline
      kybasche
      I've searched the web for quite some time now, stumbling over the various explanations on how to import CSV files into arrays in Sketchup's Ruby.
      I think, if it's possible, I just need a dumbed down explanation on how to do it; my Ruby force is very very weak.
      Let's say I have the following as a CSV:
      1,2,3,4,5
      yes,no,2
      I would like to then create an array to hold each of the rows of values, such that I end up with:
      array_1 = [1, 2, 3, 4, 5]
      array_2 = ["yes", "no", 2]
      When I follow http://groups.google.com/group/sketchupruby/browse_thread/thread/d25a302dece3b21b/7c11cb4541613773?lnk=gst&q=foltz+csv#7c11cb4541613773
      using:
      csv_data = []
      f = File.open(path,'r')
      f.each_line{|line| csv_data.push line.split(",")}
      I end up with:
      csv_data = [["1.0", "2.0", "3.0", "4.0", "5.0\n"], ["yes", "no", "2.0\n"]]
      note the end of line indicators still being present (\n)
      Using the next line:
      headers = csv_data.shift.map {|i| i.to_s }
      returns:
      headers = ["1.0", "2.0", "3.0", "4.0", "5.0\n"]
      where headers[0] = 1.0, headers[1] = 2.0, etc.
      That's pretty good.
      The last line:
      string_data = csv_data.map {|row| row.map {|cell| cell.to_s } }
      returns:
      string_data = [["yes", "no", "2.0\n"]]
      where string_data[0] = ["yes", "no", "2.0\n"]
      Not great.
      using a similar line as for "headers":
      headers2 = string_data.shift.map {|i| i.to_s }
      gets me to:
      headers2 = ["yes", "no", "2.0\n"]
      Better,
      but still with that pesky \n.
      Is there a better way to do this? And how do I avoid the \n?
      What about if there are more than 2 lines?
      I looked over Jim Foltz/Dan Rathbun's method, but I don't understand the code well enough to manipulate the parts that I want to use (it includes an IO schmealy that I'm not familiar with).
      Any hints would be greatly appreciated. Thanks much as always!
      Derek
        Try
        lines=IO.readlines(csvfilepath)
        >>> ["1,2,3,4,5\n", "yes,no,2\n"]
        Then use
        array=[]
        lines.each{|line|
          line.chomp!
          ### >>> "1,2,3,4,5"
          array << line.split(",")
          ### >>> ["1", "2", "3", "4", "5"]
        Then to convert from 'strings' to say an integer use .to_i or a float .to_f on the 'columns' thus - let's use the second line (array[1]) as an example, you might want to set 'yes/no' to true/false booleans, and the 3rd column to a number if you can...
        if array[1][0].downcase=="yes"
          test0=true
        else
          test0=false
        ### etc
        if array[1][2]=~/^[.0-9]/
          test2=array[1][2].to_f
        else ### leave it as a string ?
          test2=array[1][2]
        How you deal with the data once you have it in an array is up to you 😮
        • K Offline
          kybasche
          Brilliant.
          Thanks!
          D
          • Dan RathbunD Offline
            Dan Rathbun
            see topic: [Code] reading a CSV file
            Ruby help questions belong in the Developers forum,
            where you can find the [Code Snippets] index.
            I'm not here much anymore.
            • K Offline
              Ken007
              Hey!
              I have a problem that's been bothering me for quite a while now. Its like this that I have created a few 3D models in Sketchup 8 (the freely downloadable version) and now I want to geo locate them as per their GPS Co-ordinates (so i'm not looking to go through the usual 'add location button'. Now that thing is, I have written a script for sketchup to open the .skp files that contain the 3D models that I've created and I've linked it to another script that adds the GPS location as well as exports it to the desired location. The problem is that all of this happens through a GUI that the script generates. I want all this to occur directly through a database (for example MS Excel) such that the "name of the model", the "GPS co-ordinates/lat-longs" are taken as an input from the Excel database. The code I've written is as follows: (It is fully functional, though, I'm relatively new to sketchup so dont mind if it's a wee bit shabby)
              This is the code that opens the 3D model::
              prompts = ["Status"]
               defaults = [""]
               list = ["House|Garden|Palace|Dog house"]
               input = UI.inputbox prompts, defaults, list, "Choose a template"
               if input[0].to_s.eql? "Garden"
               result = Sketchup.open_file "E;\\GoogleEarth\\FINALFINAL\\NewFolder\\garden.skp"
               elsif input[0].to_s.eql? "House"
               result = Sketchup.open_file "E;\\GoogleEarth\\FINALFINAL\\NewFolder\\house.skp"
               elsif input[0].to_s.eql? "Palace"
               result = Sketchup.open_file "E;\\GoogleEarth\\FINALFINAL\\NewFolder\\palace.skp"
               elsif input[0].to_s.eql? "Dog house"
               result = Sketchup.open_file "E;\\GoogleEarth\\FINALFINAL\\NewFolder\\dog_house.skp"
               load 'C;\Documents and Settings\91014276\Desktop\untitled(3).rb'
              and this is 'untitled(3).rb' that actually geo locates the 3D model and exports it to the desired location::
              prompts = ["Latitude", "Longitude", "Location", "Destination Drive"]
               defaults = ["", "", "xyz", "E;\\Examples"]
               list = ["", "", ""]
               input = UI.inputbox prompts, defaults, list, "About the WEC"
              model = Sketchup.active_model
              # This is the bit that actually sets the geo-location.
                shadowinfo = model.shadow_info
                shadowinfo["City"] = "Unknown"
                shadowinfo["Country"] = "Unknown"
                shadowinfo["Latitude"] = input[0].to_f
                shadowinfo["Longitude"] = input[1].to_f
              georef = model.georeferenced?
              key = "GeoReference"
                model.set_attribute key, "GeoReferenceNorthAngle", 358.646700673226
                model.set_attribute key, "UsesGeoReferencing", true
                model.set_attribute key, "Longitude" , input[1].to_f
                model.set_attribute key, "Latitude" ,  input[0].to_f
                model.set_attribute key, "ModelTranslationX" ,  -12901579.2256146
                model.set_attribute key, "ModelTranslationY" , -214086056.635273
                model.set_attribute key, "ModelHereState", ""
                model.set_attribute key, "ModelHereZoom", 19
                model.set_attribute key, "ModelTranslationZ" , 0.0
                model.set_attribute key, "LocationSource" , "Google Earth"
                model.set_attribute key, "ZValueCentered" ,  0.0
                model.set_attribute key, "TimeStamp", 1296598526
              # Export model to kmz file for Google Earth
                model.export "#{input[3]}\\ #{input[2]}.kmz", true
                result = UI.messagebox "Is that all or would you like to try another?", MB_YESNO
               if result == 6 # Yes
                 load 'C;\Documents and Settings\91014276\Desktop\untitled(5).rb'
               elsif result == 7 # No
                 UI.messagebox ("Alrighty then!")
              In the above code 'input[0].to_f' and 'input[1].to_f' are the Latitude and Longitude co-ordinates where the model has to be placed.
              Im in need of some desperate help here so please...err..help!
                Ken... I've given you an example in the 'parallel thread' that you started.
                • K Offline
                  Ken007
                  Yep, got that TIG. Thanks..and sorry for repeating the post.
