    Reduce number of Segments in Arc
    3 Posts 2 Posters 1.0k Views 2 Watching
    • R
      Rob Pigden
      I need to reduce the number of Segments in a Arc. Currently the field where I would edit this in Entity Info is grey and won't let me change it. Am I right in thinking you can edit the number of segments?
      • GaieusG
        Hi Rob,
        Yes, you can change the segment number - as long as that arc has no been affected by other geometry. If you PushPull it to a 3D shape (like a half cylinder for instance) or use the follow me tool on an arc profile, you can no longer edit it however.
        • R
          Rob Pigden
          Ahh... that would be why then - I have extruded the face up to create a 3D shape.
          Thanks for your quick reply!
