    Min. z value of some points
    12 Posts 5 Posters 639 Views 5 Watching
    • N Offline
      niccah
      Hi!
      I have lots of 3D points: points = [[1, 2, 3], [2, 3, 5], ...]
      Is there a easy way to get for example the minimum z value of all these points in Ruby?
      At the moment I have a points.each loop and compare every z value with the last one....
      Thanks for your help!
        min = points.inject(0) { |m,pt| ( pt.z < m ) ? pt.z : m }
        Inject have many neat usages - I noted a couple of examples: http://forums.sketchucation.com/viewtopic.php?t=41176&p=364915
          Haven't checked if it is faster, but BoundingBox might help:
          <span class="syntaxdefault">bb </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">BoundingBox</span><span class="syntaxkeyword">.new<br /></span><span class="syntaxdefault">bb</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> points </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">min </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> bb</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">min</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">z</span>
          Since it's SU's native code doing the handling of the points, it might yield faster calculations.
          • N Offline
            niccah
            oh thank you very much!
            I saw the function "inject", but I ignored them because I thought, that's not interesting for me.
            Just for the sake of completeness: One have to add a "Geom::" in the front of "BoundingBox.new"
            Thanks a lot again for your help!
            br
              👍 Good catch! Updated the example.
              • fredo6F Offline
                fredo6
                to be absolutely accurate, I guess the inject statement should be
                min = points.inject(points[0].z) { |m,pt| ( pt.z < m ) ? pt.z : m }
                Fredo
                PS: Did not know this method, as it is not documented in the Pragmatic Programmer's guide. Seems useful and elegant
                • Dan RathbunD Offline
                  Dan Rathbun
                  Do not use the object reference from that OLD guide, which was written in the Ruby v 1.6.x timeframe. (The tutorial text is still relevant and recommended, however.)
                  Instead use the v 1.8.6 CHM here
                  or access on-line http://www.ruby-doc.org/core-1.8.6/index.html.
                  Note that these methods come from the mixin module Enumerable which is mixed into Array, Hash, IO (and subclasses, such as File,) Range, String, Struct, ... etc.
                  I'm not here much anymore.
                    Dan Rathbun
                    At, one time, in another thread, we were comparing various methods of getting min and max, speedwise.
                    There is also:
                    min_z = points.min {|a,b| a.z <=> b.z }
                    Can't remember which was the faster.
                    P.S.: Because min and max are method names in Enumerable, and that they are mixed into quite a few classes, .. it is recommended to not use them as var names.
                    Difference them. It seems that the API's tradition is to add an "_" and then a descriptor: min_x, min_y, min_z, min_height, min_width, min_size, etc.
                    • N Offline
                      niccah
                      This forum is amazing!
                      I learn a lot from you! Thanks a lot for all these information!
                        david.
                        This is how I would do it:
                        minZ = points.collect { |pt| pt.z }.min
                          Dan Rathbun
                          @david: Your example should be slower, as it must iterate 2 arrays, and also create a temporary array.
                          Why ?? (I suspect you like the "readability" of your version.)
                            david.
                            Yes, readability. If it was operating on large quantities of data, I would definitely use your suggested method.
