    [Plugin] Angular Dimension
    63 Posts 14 Posters 75.4k Views 14 Watching
      slbaumgartner
      This tool is an extensive rewrite and enhancement of the idea from Didier Bur's dim_angle.rb. It draws angular dimensions onto a SketchUp model. Changes from Bur's original include:
      • user input of desired radius of angle arc, modifiable after drawing until next angle is started or another tool is selected
      • user selection of inside (<180) or outside (>180) angle, with cursor indication of mode, modifiable after drawing until next angle is started or another tool is selected
      • packaging of drawn elements into a named Group
      • undo capability
      • clockwise vs counterclockwise selection order does not matter
      To install, download and unzip the attached file in your Plugins directory.
      [edit] The original version works for Windows but has issues on a Mac. Michaelv and Driven worked on it to make it compatible. If you have a Mac, you should download the second version attached.
      [another edit] After finally getting my hands on a Mac, I discovered that the reason for all the struggling with the cursors is that on the Mac, SketchUp is not happy with the color profile info that my Windows pixel editor put into the png files. I opened them in an editor on the Mac, touched them and saved, and then they work. This is especially puzzling since other apps on the Mac are quite happy with these files, just not SketchUp! Anyway, those using Macs should load the final version that Michaelv attached to the last post in this thread.
      Get the latest version [PC/MAC] from the PluginStore http://sketchucation.com/pluginstore?listtype=1&author=0&category=0&search=angular+dimension&submit=%3F
        driven
        hi,
        it's holding on to the 'Orbit' or 'Pan' cursor if I use either between angles.
        it's own cursor comes back and functions, but is hidden behind the hand.
        I'm on a mac
        otherwise it appears to be working, well done. no error messages...
        john
          slbaumgartner
          @driven said:
          hi,
          I'm on a mac
          john
          Hmmm...it doesn't do that on my PC. I don't have a Mac to test on. Maybe someone in the group who has a Mac can help sort this out?
            driven
            I just read your script and your cursors use all UPPERCASE which was actually failing gracefully, ie. '@cursor' not defined, but the tool still works.
            I had a look at your cursor images and see that they had never appeared. I'm getting the 'snap to' squares...
            I'll downcase the cursor names and see if that works, but I suspect 'Tab' key will be an issue on mac.
            john
              slbaumgartner
              @driven said:
              john
              That seems unlikely...all uppercase is pretty typical convention for constants in Ruby, and should have nothing to do with Mac vs PC. If you are finding @cursor not defined, that seems more likely a problem with the path to the icon files. Are they installed in Plugins/draw_dim_angle?
              Try this: open the Ruby Console window and type DrawAngleDimTool::IN_ICON into the input space. The output space should then display the path for interior.png. If the path is mangled or isn't where you installed the png image, that is the problem. You can also type DrawAngleDimTool::IN_CURSOR and you should get a number back, probably somewhere a bit more than 50000. If that doesn't work, SketchUp failed to load the image file.
              If you look at onKeyDown, there is a code snippet to print the keycode you get on the Mac. Please let me know what value you get and I'll see if I can code in a trap for PC vs Mac.
                driven
                on closer inspection, everything seems fine? except the onKeyDown. EDIT: swapped from Tab to Esc and I still can't get outside dims or cursors
                very few ' onKeyDown' work on macs. here's a list from today.
                PLATFORM = i686-darwin8.10.1
                SEQUENCE 0 of 5 [Function Keys]
                DN F2 Key 50 flags 0 rpt 1
                UP F2 Key 50 flags 256 rpt 1
                DN F3 Key 51 flags 0 rpt 1
                UP F3 Key 51 flags 256 rpt 1
                DN F6 Key 54 flags 0 rpt 1
                UP F6 Key 54 flags 256 rpt 1
                DN F12 Key 63243 flags 0 rpt 1
                UP F12 Key 63243 flags 8388864 rpt 1
                SEQUENCE 1 of 5 [Modifiers Keys]
                DN Shift alone Key 131072 flags 131330 rpt 1
                UP Shift alone Key 131072 flags 256 rpt 1
                DN Ctrl alone Key 262144 flags 262401 rpt 1
                UP Ctrl alone Key 262144 flags 256 rpt 1
                DN Alt alone Key 524288 flags 524576 rpt 1
                UP Alt alone Key 524288 flags 256 rpt 1
                DN Cmd alone Key 1048576 flags 1048840 rpt 1
                UP Cmd alone Key 1048576 flags 256 rpt 1
                SEQUENCE 2 of 5 [Arrow Keys]
                UP UP Key 63232 flags 10486016 rpt 1
                UP RIGHT Key 63235 flags 10486016 rpt 1
                UP DOWN Key 63233 flags 10486016 rpt 1
                UP LEFT Key 63234 flags 10486016 rpt 1
                SEQUENCE 3 of 5 [Validation Keys]
                DN RETURN Key 13 flags 0 rpt 1
                UP RETURN Key 13 flags 256 rpt 1
                UP TAB Key 9 flags 256 rpt 1
                UP DEL Key 127 flags 256 rpt 1
                UP BACKSPACE Key 63272 flags 8388864 rpt 1
                DN ESCAPE Key 27 flags 0 rpt 1
                UP ESCAPE Key 27 flags 256 rpt 1
                SEQUENCE 4 of 5 [Numbers Keys (Numpad not common)]
                UP 1 Key 49 flags 256 rpt 1
                UP 2 Key 50 flags 256 rpt 1
                UP 3 Key 51 flags 256 rpt 1
                UP 4 Key 52 flags 256 rpt 1
                UP 5 Key 53 flags 256 rpt 1
                UP 6 Key 54 flags 256 rpt 1
                UP 7 Key 55 flags 256 rpt 1
                UP 8 Key 56 flags 256 rpt 1
                UP 9 Key 57 flags 256 rpt 1
                UP 0 Key 48 flags 256 rpt 1
                UP - Key 45 flags 256 rpt 1
                UP = Key 61 flags 256 rpt 1
                UP / Key 47 flags 256 rpt 1
                UP [ Key 91 flags 256 rpt 1
                UP ] Key 93 flags 256 rpt 1
                SEQUENCE 5 of 5 [Alpha keys (do not use Shift)]
                UP s Key 115 flags 256 rpt 1
                UP c Key 99 flags 256 rpt 1
                UP r Key 114 flags 256 rpt 1
                complements of a Fredo script c.2007 with a slight update.
                john
                  slbaumgartner
                  @driven said:
                  john
                  Based on this, it looks like maybe it would work if you rename onKeyDown to onKeyUp, as it looks like the up is reported for TAB as key 9. Could you try that and let me know if it works?
                  Steve
                    driven
                    > load('/Library/Application Support/Google SketchUp 8/SketchUp/plugins/draw_angle_dim.rb')
                    true
                    > @cursor
                    nil
                    > DrawAngleDimTool;;IN_CURSOR
                    50013
                    > DrawAngleDimTool;;OUT_CURSOR
                    50014
                    No cursor, no outside dims
                    Pressing Tab just strobes the 'Input Box'
                    john
                      slbaumgartner
                      > true
                      > > @cursor
                      > nil
                      > 50013
                      > 50014
                      john
                      The responses to IN_CURSOR and OUT_CURSOR say that the cursors were created, though I'm not sure that means they found the image files. The response of nil to @cursor indicates nothing, since @cursor is an instance variable not a global. So, the problem still seems to be that the keypress is not toggling the mode to outside. Please try the attached, which looks for the up key event (will not trigger until tab key is released) and let me know if it works.
                      draw_angle_dim.rb
                        driven
                        the path is fine, I just didn't have that in the log I posted, so it's included here.
                        true
                        > DrawAngleDimTool;;IN_ICON
                        /Library/Application Support/Google SketchUp 8/SketchUp/plugins/draw_angle_dim/interior.png
                        > puts "cursor File Exists? " + File.exists?(DrawAngleDimTool;;IN_ICON).to_s
                        cursor File Exists? true
                        nil
                        with the latest file the Dim Angle itself is switching, but still no custom cursors.
                        because Tab also toggels focus on the Inputbox, I changed that to use VK_ALT || 524288
                        which is more in line with the standard tools and avoids the focus toggling issue.
                        so the tool functions fully now, just no curors...
                        john
                          slbaumgartner
                          I have to admit that I am lost and without a Mac I don't know what else to suggest...sorry! If anyone else can figure this out, I'd love to hear.
                            Michaelv
                            Same as John,
                            Substituted VK_ALT on line 350 for == 9 so that option key toggles.
                            I have no cursor, but I'm working on it.
                            Also I will include a text to outline what key toggles.
                            Otherwise functions great.
                              slbaumgartner
                              The mode key seems to be a no-win situation! Maybe I should think of a different mechanism to change the mode. On a PC the TAB key is unassigned, but the VK_ALT activates the File menu! On a Mac, the TAB key is preassigned, but not VK_ALT! By the way, when I try to use VK_ALT on the PC, the cursor alternately disappears and reappears as I press the key! Something similar may be what is happening on the Mac.
                                driven
                                @Michaelv,
                                the key generator is on the forum, but if you want a slightly updated version, that's easy to add to... I'll PM it to you.
                                BTW. if you use either one VK_ALT or 524288 it toggles from the Alt key, but if you use the ruby either/or VK_ALT || 524288 then not only does ALT toggle, so does RETURN!! which shows as 13 when I ran the test. SU key mapping needs checking.
                                as for the icons, they work on toolbars, so the file and path are ok (but I made new ones as well), their just not being seen by ruby,
                                I'm having a similar problem in another script where only the 'before' half an if not block being seen. Is this a Ruby 1.8.5 (mac SU ruby) issue?
                                john
                                  driven
                                  Have you set that as a system shortcut?... do you have assistive devices activated?
                                  Does Alt open the File Menu when you use 'move' or 'scale' tools?
                                  are your Plugins still all on? [I turn mine off to test new rubies on there own]
                                  john
                                  EDIT: did you try **524288** that work here as well.
                                    slbaumgartner
                                    john
                                    Alt key opening a menu is a standard PC shortcut - I didn't do anything special, no assistive devices. Interestingly, ALT seems to affect just about every tool except move, on which it does nothing that I can see! And with the Paint Bucket it displays a dropper icon to let you select a Material to match so long as you hold the ALT key depressed. Goes back to the paint bucket when released. You gotta love consistency and portability!
                                    I didn't turn off other plugins, but on my PC the tool functions ok so I didn't think that would add anything to this mix.
                                    Regarding the cursors, is there any chance that the problem is with png files? Do you have other tools with custom cursors from png files that work?
                                      driven
                                      thought you were taking mac...
                                      it should 'move' a copy [with an added + symbol]
                                      ohhh yerrr
                                      All of SU's cursors are png's so that's not the problem.
                                      I want them to work now because I made new ones.... damm
                                      didn't really need the cursor before.
                                      john
                                        slbaumgartner
                                        ohhh yerrr
                                        john
                                        I'm on a PC but trying to help get this tool to work for people with Macs...
                                        On a PC, the CTRL key toggles the move tool to copy, not ALT!
                                        Re the cursors, do you have any examples of a tool with custom cursors that do work? I'd like to look at the Ruby to see what it does. I thought I was following the documented code...
                                        steve
                                          driven
                                          some progress...
                                          if I use either of these changes, I get the inside cursor and a one-off toggle.
                                            def onKeyDown(key, rpt, flags, view)
                                                if key ==  VK_ALT
                                              #  @inside=nil         # uncomment this with the original order below i.e. true = false
                                                !@inside = @inside     # or switch it to false = true     orig.  @inside = !@inside
                                                 if @inside
                                                  @cursor = IN_CURSOR
                                                  else
                                                  @cursor = OUT_CURSOR
                                          not sure what to look for next... john
                                            driven
                                            Chris Fulmars 'shapebender.rb' come easily to mind, in the Plugin section here.
                                            I got one step more with trying versions of this, I can switch from inside to out logos once...
                                            could you split this into 2 separate actions, holding down the Alt is common for SU tools, as apposed to toggling...
                                                  if key ==  VK_ALT
                                                   @inside = false && @cursor = OUT_CURSOR
                                                    else
                                                    if key ==  !VK_ALT
                                                     @inside = true
                                                     @cursor = IN_CURSOR
                                            • 1 / 4
