    [Plugin] Angular Dimension
    63 Posts 14 Posters 75.5k Views 14 Watching
      driven
      > load('/Library/Application Support/Google SketchUp 8/SketchUp/plugins/draw_angle_dim.rb')
      true
      > @cursor
      nil
      > DrawAngleDimTool;;IN_CURSOR
      50013
      > DrawAngleDimTool;;OUT_CURSOR
      50014
      No cursor, no outside dims
      Pressing Tab just strobes the 'Input Box'
        slbaumgartner
        > true
        > > @cursor
        > nil
        > 50013
        > 50014
        The responses to IN_CURSOR and OUT_CURSOR say that the cursors were created, though I'm not sure that means they found the image files. The response of nil to @cursor indicates nothing, since @cursor is an instance variable not a global. So, the problem still seems to be that the keypress is not toggling the mode to outside. Please try the attached, which looks for the up key event (will not trigger until tab key is released) and let me know if it works.
        draw_angle_dim.rb
          driven
          the path is fine, I just didn't have that in the log I posted, so it's included here.
          true
          > DrawAngleDimTool;;IN_ICON
          /Library/Application Support/Google SketchUp 8/SketchUp/plugins/draw_angle_dim/interior.png
          > puts "cursor File Exists? " + File.exists?(DrawAngleDimTool;;IN_ICON).to_s
          cursor File Exists? true
          nil
          with the latest file the Dim Angle itself is switching, but still no custom cursors.
          because Tab also toggels focus on the Inputbox, I changed that to use VK_ALT || 524288
          which is more in line with the standard tools and avoids the focus toggling issue.
          so the tool functions fully now, just no curors...
            slbaumgartner
            I have to admit that I am lost and without a Mac I don't know what else to suggest...sorry! If anyone else can figure this out, I'd love to hear.
              Michaelv
              Same as John,
              Substituted VK_ALT on line 350 for == 9 so that option key toggles.
              I have no cursor, but I'm working on it.
              Also I will include a text to outline what key toggles.
              Otherwise functions great.
                slbaumgartner
                The mode key seems to be a no-win situation! Maybe I should think of a different mechanism to change the mode. On a PC the TAB key is unassigned, but the VK_ALT activates the File menu! On a Mac, the TAB key is preassigned, but not VK_ALT! By the way, when I try to use VK_ALT on the PC, the cursor alternately disappears and reappears as I press the key! Something similar may be what is happening on the Mac.
                  driven
                  @Michaelv,
                  the key generator is on the forum, but if you want a slightly updated version, that's easy to add to... I'll PM it to you.
                  BTW. if you use either one VK_ALT or 524288 it toggles from the Alt key, but if you use the ruby either/or VK_ALT || 524288 then not only does ALT toggle, so does RETURN!! which shows as 13 when I ran the test. SU key mapping needs checking.
                  as for the icons, they work on toolbars, so the file and path are ok (but I made new ones as well), their just not being seen by ruby,
                  I'm having a similar problem in another script where only the 'before' half an if not block being seen. Is this a Ruby 1.8.5 (mac SU ruby) issue?
                    driven
                    Have you set that as a system shortcut?... do you have assistive devices activated?
                    Does Alt open the File Menu when you use 'move' or 'scale' tools?
                    are your Plugins still all on? [I turn mine off to test new rubies on there own]
                    EDIT: did you try **524288** that work here as well.
                      slbaumgartner
                      Alt key opening a menu is a standard PC shortcut - I didn't do anything special, no assistive devices. Interestingly, ALT seems to affect just about every tool except move, on which it does nothing that I can see! And with the Paint Bucket it displays a dropper icon to let you select a Material to match so long as you hold the ALT key depressed. Goes back to the paint bucket when released. You gotta love consistency and portability!
                      I didn't turn off other plugins, but on my PC the tool functions ok so I didn't think that would add anything to this mix.
                      Regarding the cursors, is there any chance that the problem is with png files? Do you have other tools with custom cursors from png files that work?
                        driven
                        thought you were taking mac...
                        it should 'move' a copy [with an added + symbol]
                        ohhh yerrr
                        All of SU's cursors are png's so that's not the problem.
                        I want them to work now because I made new ones.... damm
                        didn't really need the cursor before.
                          slbaumgartner
                          ohhh yerrr
                          I'm on a PC but trying to help get this tool to work for people with Macs...
                          On a PC, the CTRL key toggles the move tool to copy, not ALT!
                          Re the cursors, do you have any examples of a tool with custom cursors that do work? I'd like to look at the Ruby to see what it does. I thought I was following the documented code...
                          steve
                            driven
                            some progress...
                            if I use either of these changes, I get the inside cursor and a one-off toggle.
                              def onKeyDown(key, rpt, flags, view)
                                  if key ==  VK_ALT
                                #  @inside=nil         # uncomment this with the original order below i.e. true = false
                                  !@inside = @inside     # or switch it to false = true     orig.  @inside = !@inside
                                   if @inside
                                    @cursor = IN_CURSOR
                                    else
                                    @cursor = OUT_CURSOR
                            not sure what to look for next... john
                              driven
                              Chris Fulmars 'shapebender.rb' come easily to mind, in the Plugin section here.
                              I got one step more with trying versions of this, I can switch from inside to out logos once...
                              could you split this into 2 separate actions, holding down the Alt is common for SU tools, as apposed to toggling...
                                    if key ==  VK_ALT
                                     @inside = false && @cursor = OUT_CURSOR
                                      else
                                      if key ==  !VK_ALT
                                       @inside = true
                                       @cursor = IN_CURSOR
                                driven
                                here's some I made earlier.
                                so we have to get them working.... john
                                  driven
                                  got it...... could be tidier but it's working
                                        if key ==  VK_ALT
                                         @inside = false
                                         @cursor = nil
                                       # end
                                        # redraw in new mode if appropriate
                                        if @drawn
                                          # undo the previous operation before redrawing
                                          # this avoids buildup of unneeded operations on
                                          # the undo stack
                                          Sketchup.undo if @state==0
                                          draw_angle_dim
                                          else
                                          # make sure the cursor change takes effect immediately
                                          # without this it doesn't change until the user moves
                                          # the mouse
                                          UI.set_cursor(@cursor)
                                  def onKeyUp(key, rpt, flags, view)
                                        if key ==  VK_ALT
                                         @inside = true;
                                         @cursor = nil
                                         @cursor = IN_CURSOR
                                    slbaumgartner
                                    How strange! The key feature seems to be the assignment of nil before assignment of the new cursor. I can't imagine why that would be necessary, but if it works...
                                      driven
                                      This is something I was looking at today for the other ruby issue, and I just thought I'd play around with the assumption that
                                      having Booleans and conditionals mixed together Can cause issues like false = false ==> true
                                      http://stackoverflow.com/questions/3783483/odd-ruby-if-statement-question
                                        driven
                                        hi Steve
                                        I missed this earlier, but that could explain the problem... there are so many gotcha's...
                                        one thing that happens now is the to icon switches on button up but the @inside changes on next mouse click, could a conditional delay the icon?
                                        you should probably move 'cursor bits' of this to the developers forum, tidier for plugin browsers and you might get some answers from people who know what their doing....
                                        I just try and make other peoples scripts work on mac's, and write a few applescript/shell/su type helpers.. and bets test for anyone really...
                                          Michaelv
                                          Well at this point in regard to the mod keys for scripts, I'm figuring that the easiest way is to have a Mac and a PC version of the script. Not only it's the easiest from the point of view of scripting, but it allows to use different modifiers, which is more within the usual practice of each machine.
                                          I have a version ready for you, including text but there is still the cursor issue.
                                          I worked on the cursor issue yesterday and it's a tough nut. I changed the cursor scripting to make it similar to the API example and to another script I have (in progress) where it works. And it still doesn't work 😲 . There is no difference between the two, yet it doesn't work in this script, and there is still the orbit and pan cursor remanence issue. So something else is going on, which I have to figure out. Maybe today.
                                            driven
                                            @Michaelv
                                            hi,
                                            the cursors work on OSX 10.5.8 with the script above if inserted into the original. did you try it?
                                            • 1 / 4
