    Is there a simple way to customize the contents of a toolbar
    3 Posts 2 Posters 274 Views 2 Watching
    • genma saotomeG Offline
      genma saotome
      I find I use 1/2 to 3/4 of the icons in any of the standard Google-provided toolbars and feel the other icons are simply clutter. Most software has been providing the means to do that since, oh, Windows 3.1 and it's a surprise to me that in 2012 SU doesn't appear to let one to do that. So is there a simple way to customize which icons appear and which don't?
      • KrisidiousK Offline
        Krisidious
        Error 404 (Not Found)!!1
        (sketchuptips.blogspot.com)
        This Plugin allows you to build your own customized Toolbars. Creating a Toolbar is easy; Custom Toolbars creates a "Toolbars" folder in your SketchUp Plugins folder. Create a .txt file in this Toolbars folder and give it the same name as you want the name of the Toolbar. Then, edit the .txt file and simply list the name of the tool you would like to appear in the Toolbar.
        you can also take something like CadFather's CD_Archiland toolbar or the Powerbar and see how they call up different commands to be on a toolbar. this may require creating some small images on your part.
        http://forums.sketchucation.com/viewtopic.php?f=323&t=13760
        By: Kristoff Rand
          genma saotome
          Thank you... the first one does all that I need. Very much appreciated.
