    System preference and extensions problem
    4 Posts 2 Posters 287 Views 2 Watching
    • kenK Offline
      ken
      Need a little help
      I can not determine the reason I have two "Quarr JSAlign" in my extension menus.
      Any help would be appreciated.
      Thank you in advance.
      Ken
        What does your Plugins folder look like? Do you see a "Compatibility Files" button when you browse the folder with Explorer?
        • kenK Offline
          ken
          Thomthom
          No, there is no "Compatibility Files" folder or button.
          Ken
          • kenK Offline
            ken
            I have two "Quarr JSAlign" in my extension menus. It appears that this is a problem with the plugin's file. I did notice that the terms require 'sketchup.rb'
            require "extensions.rb" and I changed the "extensions.rb" to 'extensions.rb' thinking this may be the problem, but no change.
            So if the plugins registers twice will that cause a problem or does the plugin need to be changed.
            Ken
