    Missing Plugin or it was a native tool?
    2 Posts 2 Posters 206 Views 2 Watching
    • S
      sakis
      Hello all. I'm totally new in the 3D"world". I end up using SU after trying with that beast called 3dsMax.
      Ok, what's my problem?
      Well, in 3dsmax, when you draw a cube there's that dialog box where you set the "segments" of the cube in X,Y and Z axis.
      Till yesterday, I had that tool in SU(v.8). I could divide a face in even sub-faces then use the pushpull tool and...voila!
      It's like wanting make contours but on all faces of the component. Anyway, I had to re-install SU again for some reason
      and now I cant find that tool any more! Probably I won't need that tool in the future but I go crazy just because I don't know where I can get it back!!!
      Can anyone help me please? Do you guys know what I'm talking about?
      Thank You
      • sdmitchS
        sdmitch
        Sounds like the plugin Shapes which is normally found under the Draw menu. The option is called Box instead of cube.
        http://sdmitch.blogspot.com/
