    Xref problem
    3 Posts 3 Posters 349 Views 3 Watching
    • john2J Offline
      john2
      I'm trying to import a dwg file in sketchup that has xref. But sketchup doesn't import that xref thing, rest of the drawing gets imported. How can i import full xref?
        I am not an expert at cad but I believe xref is not imported - only "bare" geometry (well, at least groups and blocks/components do as well as layers). TIG has an xref manager which is similar to tht of cad but I don't think it will import everything like that so you have to set up your own in SU.
        Latest version:
        http://forums.sketchucation.com/viewtopic.php?t=7329
        Some description for an older version:
        http://forums.sketchucation.com/viewtopic.php?t=7289
        • pbacotP Offline
          You want to "bind" the XREF to the drawing before import (do this to a copy of the drawing). Or you can import a dwg of the XREF file separately.
