    Web dialog problem
    11 Posts 5 Posters 901 Views 5 Watching
    • P Offline
      piranesi
      Hi All,
      I'm a complete newbie to Ruby and programming for Sketchup. I use Autocad and Sketchup to model my models. I saw some great plugins to assign materials to layers. (Useful when you work in both Autocad and Sketchup). Still I wanted to write my own plugin and learn Ruby by combining a lot of snippets from different, brilliant plugins.
      So this is my problem. When I use webdialog.set_file ('somehtml.html') everything runs smooth. But when I add a variable e.g. htmlstr = "here I put all the contents from the somehtml.html file" and use webdialog.set_html I get an error.
      I tried several things but nothing seems to work. Please help me. What am I doing wrong?
      Thank you!
      Jeroen
      I added the script:
      The info assigned to html variable is the same as the info from the mbl.html file used in the wb.set_file command. Therefore I did not add the HTML file.
      # mlb.rb
      # Material By Layer v0.4
      # jeroenverdonschot@gmail.com
      require 'sketchup.rb'
      def mbl_main
      	html = <<DATA
      	<html><head><title>Material by Layer</title><meta http-equiv="Content-Type" content="text/html" charset="utf-8"/>
      		<style type="text/css">
      			body {
      				font-family; Helvetica, Geneva, Arial,
      				SunSans-Regular, sans-serif;
      				font-size; 12px;
      			h4 {
      				font-size; 12px;
      			select {
      				background; transparent;
      				width; 275px;
      				padding; 0px;
      				font-size; 14px;
      				border; 0px solid #ccc;
      				height; 34px;
      				overflow; hidden;
      		</style>
      	</head>
      	<body>
      	<h4>Choose Layer;</h4><select name="combo" width="200"></select><br>
      	<h4>Choose Material;</h4><select name="combo2"></select>
      	<form name="checkboxes">
      	<input type="checkbox" checked="yes" name="include" value="faces" /> include faces<br />
      	<input type="checkbox" checked="yes" name="include" value="groups" /> include groups<br />
      	<input type="checkbox" checked="yes" name="include" value="components" /> include components
      	</form>
      	<script type="text/javascript">
      	function rubyCalled( callback_name, string ) {
      		if ( (typeof string) == 'undefined' ) string = '';
      		window.location.href = 'skp;' + callback_name + '@' + string;
      	function call_ruby( msg ) {
              location = 'skp;catch_data@' + msg;
      	function from_ruby( data, namecombo ) {
      		var names;
      		eval( 'names = ' + data );
      	    for ( var x in names) {
      		var optn = document.createElement("OPTION");
      		var combo = document.getElementById( namecombo );
      		optn.text = names[x];
      		combo.options.add(optn);
      	function closer( button_text ) {
              if ( button_text == 'cancel' ) {
                  call_ruby( 'cancel' );
                  //return;
              if ( button_text == 'ok' ) {
      		    var i =  new Array(5);
      			i[0] = document.getElementById("combo").selectedIndex;
      			i[1] = document.getElementById("combo2").selectedIndex;
      			for (x=0; x<document.checkboxes.include.length; x++){
      			i[x+2]=document.checkboxes.include[x].checked;
      			call_ruby(i);
              return;
          } // end of closer()
      	rubyCalled( 'layers' )
      	rubyCalled( 'materials' )
      	</script>
      	<center>
      	<button type="button" style="width;80;" onclick = "closer( 'ok' )">OK</button>
      	<button type="button" style="width;80;" onclick = "closer( 'cancel' )">Cancel</button>
      	</center>
      	</body> </html>
      DATA
          model = Sketchup.active_model
      	selection = model.selection
      	view = model.active_view
      	lays=model.layers
      	layNstmp=[]
      	lays.each{|l|layNstmp.push(l.name)}
      	layList = "['#{layNstmp.join('\',\'')}']"
      	mats=model.materials
      	matNstmp=[]
      	mats.each{|m|matNstmp.push(m.name)}
      	matNames= matNstmp
      	matList= "['#{matNames.join('\',\'')}']"
      	wd = UI;;WebDialog.new("Material by Layer", false, "MaterialByLayer", 310, 320, 100, 200, true)
      	wd.add_action_callback( "layers" ) do |dlg, msg|
      	script = 'from_ruby("' + layList + '", "'+ "combo" + '");'
      	dlg.execute_script( script )
      	wd.add_action_callback( "materials" ) do |dlg, msg|
      	script = 'from_ruby("' + matList + '", "'+ "combo2" + '");'
      	wd.add_action_callback( 'catch_data' ) do |another_wd, msg|
      	if msg == 'cancel'
      		wd.close()
      	else
      		ac_Array = msg.split(',') # convert from javascript to Ruby
      		pickedLayer = layNstmp[ac_Array[0].to_i]
      		pickedMaterial = matNames[ac_Array[1].to_i]
      		includeFaces = ac_Array[2]
      		includeGroups = ac_Array[3]
      		includeComponents = ac_Array[4]
      		selection.each { | entity| putCurrentRecursion(entity, pickedMaterial, pickedLayer) }
      		view.refresh
      	wd.close()
      # wd.set_file( '/mbl/mbl.html' ) THIS WORKS!
      # wb.set_html(html) # THIS DOESN'T
      wd.show()
      def putCurrentRecursion(ents,selmat,sellayer)
      	etype = ents.typename
      	case etype
      		when "Face"
      			ents.material=selmat if ents.layer.name == sellayer
      		when "Group"
      			ents.entities.each do |ent|
      				putCurrentRecursion(ent,selmat,sellayer)
      	 	when "ComponentInstance"
      			begin
      				ents.definition.entities.each do |ent|
      			rescue => err
      				puts "EXCEPTION; #{err}"
      if( not file_loaded?("mbl.rb") )
        UI.add_context_menu_handler do |menu|
              menu.add_separator
       		menu.add_item("Material by Layer") { mbl_main }
      file_loaded("mbl.rb")
        sahi
        The problem may be due to coding.
        Try to remove this.(and in html)
        • P Offline
          piranesi
          Thanks Sahi for your quick reply!
          I removed the <meta>-tag and contents. Still the same problem.
          Still the webdialog.Set_file works, the webdialog.set_html doesn't.
          I get this error from the console:
          Error: #<NameError: undefined local variable or method wb' for main:Object> C:/Program Files/Google/Google SketchUp 8/Plugins/mbl.rb:149:in mbl_main'
          C:/Program Files/Google/Google SketchUp 8/Plugins/mbl.rb:186
          I can't find the variable. I do not understand why this error is reported with the same html file/string?
          Please help, thanks in advance!
          Jeroen
            sahi
            string 133 ? split(",") ?
            which string gets the variable msg ???
            puts msg.to_s
              driven
              It's the JS that's falling down in ruby...
              if you put it in a simple WD, that works without it, you get js parsing errors from ruby with it.
              some are whitespace and some are case[Case] issues
              It's basically because the 'browser' parses the JS differently to ruby [which is either stricter or simply different],
              you need to manually parse it for ruby, then it works for both...
              here's the simple WD I tested the html in...
              dlg_html='put your html in here... I deleted the DATA tags first'
              dlg = UI;;WebDialog.new('My Dialog', true,'MyDialog', 400, 400, 150, 150, true)
              dlg.navigation_buttons_enabled = false
              dlg.set_html(dlg_html)
              dlg.show
              john
              • P Offline
                piranesi
                Thanks for your replies!
                @sahi JS returns msg with a string ("cancel") or with information about the selected items. To use the JS array I had to convert it to a Ruby array. So I used the split method.
                @driven. I think I understand the problem. I unfortunately have not enough experience/knowledge to rewrite the JS part so Ruby can understand it. So I think I'll use the separate html file and wb.set_file method.
                Thank you for your replies!
                Jeroen
                  I'm a bit late to this discussion. Have you worked out your issue now?
                  In general I recommend separating the HTML into a separate file as it's easier to manage.
                  If you are new to WebDialogs in SketchUp I can suggest a thread I started that tries to summarize many pitfalls: http://forums.sketchucation.com/viewtopic.php?f=180&t=23445#p198883
                  A side note on your code snippet, I see you use .typename to compare entity types, something I strongly recommend you avoid. It's a big performance drain. I was just finishing up a small article on that topic: http://www.thomthom.net/thoughts/2011/12/never-ever-use-typename/
                  • Dan RathbunD Offline
                    Dan Rathbun
                    The error is a simple typo
                    Did anyone read his error message ?
                    line 149 he has wb as the webdialog object reference, instead of wd !!
                    PS: this thread belongs in the Developers forum.
                    I'm not here much anymore.
                      driven
                      It may well have the typo, but when I ran his 'working bits' in the clean wd, it also has JS issues...
                      who can move these types of post?
                        I can. Already moved. See breadcrumb navigation over the topic title.
                          Dan Rathbun
                          Could be that he's using a double-quoted heredoc instead of a single-quote heredoc wrapper ??
