    Method for realistic towel and bathrobe, any ideas?
    7 Posts 6 Posters 2.2k Views 6 Watching
    • soloS Offline
      solo
      Mike, what render app are you using?
      http://www.solos-art.com
      • mitcorbM Offline
        mitcorb
        Try a search in this forum.
        Solo, drapery, curtains, bedspread... about a year and a half to 2 years ago.
        TIG Extrude Tools, Fredo Curviloft?
        Edit: Sorry, I thought he wanted modeling ideas.
        • pugz1983P Offline
          pugz1983
          Hi Mike,
          It all depends on the render engine. If you want the "real" thing you'll have to use displacement. ( Indigo, Thea , Maxwell, Fryrender, Cinema 4D . if using a render app that doesn't have displacement options, I would go with normals in kerkythea combined with a bump.
          in the att. render I used a displacement map made with pixplant 2. Render made with Indigo. I was pretty pleased with the result on the towel. Nevermind the scenery and the design. Not my best work 😳
          Greetz Twan
          • N Offline
            notareal
            In Kerkythea you could try instancing brush, but I think displacement is better for a towel. Normal or bump map will work, if you don't go too close.
            • jo-keJ Offline
              jo-ke
              for towels I've found this model at the warehouse:
              Error 404 (Not Found)!!1
              (sketchup.google.com)
              then I retextured it with that texture:
              http://www.mayang.com/textures/Fabric/html/Other%20Fabrics/index.html
              I've made a bumpmap and applied it.
              then I've got that result with twilightrender. Looks quite OK, I think...
              http://www.zz7.de
              • jo-keJ Offline
                jo-ke
                a bathrobe on hangers you can find here:
                textured with the same texture it looks like this:
                http://www.zz7.de
                • I Offline
                  indielyness
                  I'd be interested in this too, what would an experienced sketchup user do/what would a good approach be if he wanted to model a detailed bathrobe that was hanging from a hook?
