    File in use message
    Scheduled Pinned Locked Moved Google Earth
    3 Posts 1 Posters 2.8k Views 1 Watching
      Hi Bruce,
      This is weird. I don't presume you are using IE5 😲
      BTW what happens when you answer yes, download the file and upload it again after the changes?
        Use Jim's ModelID Plugin to set the model ID in any of your files (this is the number after the ?mid= sign in the URL of the model) and you can revise any existing model by updating the original file in the WH rather than uploading it as a new one (with obviously a new link).
        Although normally the "download > edit > upload" method should work, there are often glitches so I still have this little gem at hand just in case.
        http://sketchup.google.com/3dwarehouse/details***?mid=***94dd8c51d1053fcfe2d1c7fb74c7e53b
          Nice one! Smart detailing with png's!
          It is a little bit floating however
          Also, sometimes GE goes nuts when you save the file (before export) at such a sharp angle close to the ground. Not in this case but it's just on the edge of it.
