    File in use message
    Scheduled Pinned Locked Moved Google Earth
    3 Posts 1 Posters 3.0k Views 1 Watching
    • GaieusG
      Hi Bruce,
      This is weird. I don't presume you are using IE5 😲
      BTW what happens when you answer yes, download the file and upload it again after the changes?
      • GaieusG
        Use Jim's ModelID Plugin to set the model ID in any of your files (this is the number after the ?mid= sign in the URL of the model) and you can revise any existing model by updating the original file in the WH rather than uploading it as a new one (with obviously a new link).
        Although normally the "download > edit > upload" method should work, there are often glitches so I still have this little gem at hand just in case.
        http://sketchup.google.com/3dwarehouse/details***?mid=***94dd8c51d1053fcfe2d1c7fb74c7e53b
        • GaieusG
          Nice one! Smart detailing with png's!
          It is a little bit floating however
          Also, sometimes GE goes nuts when you save the file (before export) at such a sharp angle close to the ground. Not in this case but it's just on the edge of it.
