    My first rendered Concept Car!!!
    14 Posts 7 Posters 1.0k Views 7 Watching
    • K Offline
      kiwi1993
      i know its not brilliant< but not bad for a noob eh πŸ˜†
      • boofredlayB Offline
        boofredlay
        Nice.
        More views please πŸ‘
        • K Offline
          kiwi1993
          thanks πŸ˜„
          im working on another car,
          hopefully should be up tonite or some point tomo..
          Sneak preview
          • daleD Offline
            dale
            Intrigued....
            • hellnbakH Offline
              hellnbak
              Looks nice, but I gotta ask - why is it so dark? Can't make out any details at all.
              • irwanwrI Offline
                irwanwr
                that's it. i quit πŸ˜›
                • hellnbakH Offline
                  hellnbak
                  Actually I probably shouldn't have said anything, I've been at this for over a year and still can't figure out how to render anything. For your first effort it's outstanding! How about posting some photos of just the model, I'd like to see it in more detail.
                  • K Offline
                    kiwi1993
                    Here you go, i took some screenshots of the modle.
                    If you Want an even closer look the model is attached below.
                    Kberry1993Concept01.skp
                    • irwanwrI Offline
                      irwanwr
                      πŸ‘ nice model πŸ˜„
                      • ely862meE Offline
                        ely862me
                        Very good start !
                        What I would advice you is :
                        1 Keep wheels separated in groups/components
                        2 Don't use too much geometry/triangles because will be hard to reedit
                        3 Clean the backside geometry because you won't be able to Soften/Smooth proper
                        4 Use same amount of segments on arcs you draw together ,so they will fit exactly
                        5 At this stage I think you should just focus on the exterior and let the interior after you finish the body (also start the interior as a separated group)
                        6 At this stage(as a beginner) every time you start modeling a car - take yourself a car picture as reference to see how the pillars ,wheel well etc etc looks like and try to replicate those real elements but in your own shape .
                        Attached is a picture with my first concept car and with one of my best cars. Keep in mind that between them is a difference of 5 years of practicing with Sketchup .
                        This is how it should look from inside(no other back faces , everything cleaned up)
                        Have a great time !
                        Take care !
                        Elisei (sketchupper)
                        Come and See EliseiDesign
                        • K Offline
                          kiwi1993
                          WOW your amzing! and thankyou for the advice, its very much appriciated πŸ‘ πŸ‘
                          *edit
                          if nyone knows of any good plugins used for making car, that would be very much aprriciatd πŸ˜„
                          • ely862meE Offline
                            ely862me
                            These are some i use often :
                            -Artisan(commercial plugin) : http://artisan4sketchup.com/
                            -Tools on surface(free plugin) : http://forums.sketchucation.com/viewtopic.php?t=11212
                            -Joint push pull(free plugin) : http://forums.sketchucation.com/viewtopic.php?t=6708
                            -Curviloft(free plugin) : http://forums.sketchucation.com/viewtopic.php?t=28586 -FredoScale(free plugin) : http://forums.sketchucation.com/viewtopic.php?t=17948
                            -SketchyFFD(free plugin) : http://forums.sketchucation.com/viewtopic.php?t=8295
                            -Pipe along a path(free plugin) : http://forums.sketchucation.com/viewtopic.php?t=1709
                            I used these in my pdf book too http://books.sketchucation.com/ .
                            Hope it helps !
                            • K Offline
                              kiwi1993
                              Thank you for all the help, i have taken note and here is a car im currently working on.......
                              its a shame im not as good on sketchup as i am with a pencil and paper..
                                android no. 12
                                very, very good! way beyond anything I can do at the moment. My favourite is the second, though the method you're using may make things difficult in the future (I always find it easier to use triangles).
                                I'm pretty sure there's a way in vray to automatically make those sides smoother in every render, but I'm also a noob...
