    [Plugin] FredoTools - v4.6a - 21 Oct 26
    464 Posts 123 Posters 843.5k Views 121 Watching
    • fredo6F
      fredo6
      NEW RELEASE: FredoTools v3.1e - 01 Oct 17
      FredoTools 3.1e fixes a major bug preventing the correct load under Mac OSX High Sierra. So you really need to upgrade if you have upgraded or plan to upgrade to High Sierra.
      See FredoTools plugin home page for Download.
      See also main post of this thread for User Discussion.
      Fredo
      • mariochaM
        mariocha
        Hi Mac users. A litlle survey.
        Lately I'm having a small annoyance with this extension.
        If I open the pane for the tools (see image) once in a session, then SU cannot quit normally. Beachball.
        I removed all the other extension leaving only it and the Lib. Still bug.
        Anyone else ?
        update: Just did it with Curvizard.
        %(#008000)[Mario C.
        • Mousa_SAM
          Mousa_SA
          @fredo6 said:
          NEW RELEASE: FredoTools v3.1d - 28 Sep 17
          FredoTools 3.1d fixes potential bugsplat in ThruPaint. Thanks to report if you have any.
          Fredo
          Hello Fredo,
          Firstly, thanks for all of your plugins.
          I get a bugsplat when I enable Thrupaint, please check the attachment to see the bug report.
          Thrupaint bug
          • fredo6F
            fredo6
            Yes, there are cases of bugsplat, and for what whatever reason, they may occur systematically for some users. I did not find the reason and fix yet, but I am trying...
            Fredo
            • Mousa_SAM
              Mousa_SA
              Fredo
              I have made some tests and found that this issue occur when Profile builder 2 and SubD is enabled, but I installed SketchUp 2017, Profile Builder 2 and SubD on another machine and Thrupaint worked fine!
              • OxerO
                Oxer
                Hi, I found a minor issue with Thrupaint on OS X 10.11.6 & SU2017, when you make click to enter in Visual edition, the gizmo and the options window disappear immediately but "right click ->Contextual menu->Enter in Visual edition" or "Enter" work fine, for this reason for me is a minor issue.
                http://www.oxervision.blogspot.com/
                • fredo6F
                  fredo6
                  I think the problem was already signaled, and it seems this happens only on MacOS.
                  Note that you can also type Enter to activate / deactivate the gizmo.
                  Difficult for me to troubleshoot as I don't have a Mac. I made a modif blindly, just in case this improves.
                  Fredo6_FredoTools - v3.1f - 03 Nov 17 - certified - encrypted.rbz
                  Could you check if you still have the problem.
                  Fredo
                  • OxerO
                    Oxer
                    I installed that version but the issue persists.
                    Fredo like I said to you before, for me it's a minor issue.
                    • OxerO
                      Oxer
                      The FredoTools v3.1e works fine on OS X 10.11.6 & SU2016, the issue is with SU2017.
                      • fredo6F
                        fredo6
                        Even more weird.
                        Did you try with double-click on a textured face?
                        Fredo
                        • OxerO
                          Oxer
                          Yes, but this doesn't resolve the issue. Don't worry Fredo, it's a little problem but it doesn't interrupt my workflow.
                          • fredo6F
                            fredo6
                            Just try to understand what can be caused by
                            • a difference between Mac and Windows
                            • a difference between SU2016 and SU2017
                            To you get a stable gizmo when pressing Enter on a textured face ?
                            What happen if you click down, release without moving the mouse ?
                            • OxerO
                              Oxer
                              Yes, If I press Enter over a textured face the gizmo is stable. When click down the gizmo appears but it disappear immediately (1 second).
                              • fredo6F
                                fredo6
                                NEW RELEASE: FredoTools v3.1g - 11 Nov 17
                                FredoTools 3.1g fixes a bug in FredoTools::ReportLabelArea, for the CSV export in non-English languages.
                                Fredo
                                • Mousa_SAM
                                  Mousa_SA
                                  Hello Fredo,
                                  Is the thrupaint bugsplat fixed in "FredoTools v3.1g - 11 Nov 17" release?
                                  It still occur on some of my machines!
                                  Any suggestion is much appreciated.
                                  • fredo6F
                                    fredo6
                                    NEW RELEASE: FredoTools v3.2a - 24 Feb 18
                                    FredoTools 3.2a is about bug fixing and introduction of FaceTriangulator.
                                    Fredo
                                    • fredo6F
                                      fredo6
                                      NEW RELEASE: FredoTools v3.2b - 27 Feb 18
                                      FredoTools 3.2b is about a small adjustment in FaceTriangulator and some bug fixing.
                                      Fredo
                                      • R
                                        rv1974
                                        May I ask, what is the main purpose of triangulator?
                                        • fredo6F
                                          fredo6
                                          Just to divide a face into triangles, which is useful in some situations. Actually FaceTriangulator is just a byproduct of another plugin to come.
                                          Note that there exists other plugins for face trinagulation (at least one by TIG). FaceTriangulator gives the same result, but you can impose triangulation points as Construction Points on the face.
                                          Fredo
                                          • Mousa_SAM
                                            Mousa_SA
                                            Fredo
                                            Fredo, I installed this update, but SketchUp still crash when I launch the Thrupaint.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 23
                                            • 24
                                            • 14 / 24
