    Easy hole question
    5 Posts 3 Posters 1.1k Views 3 Watching
      merc
      this is def a newbe type question.
      How can I draw a hole from a flat surface to an angled surface?
      Example: A 1x6 board.. saw the end off in a 45 degree..tip board on edge.. drill a hole perpendicular to the edge so that it comes out in the center of the angled cut.
      When I push the hole I can't stop it on an angle. It is either not seen or looks like a rod protruding from the angle. I need the face of the hole flat to the face of the angle.
      Probably will step x step instruction for this simple mind.
      Merc
      • daleD Offline
        dale
        You are actually doing everything right. when you get the "rod" pushpulled through, double click to highlight both objects, and go to Edit/Intersect Faces. Then just delete the unnecessary faces, and your hole will remain.Screen shot 2011-12-19 at 6.58.37 AM.png
          merc
          thank you
          It took a few times (yea right - probably a dozen) to figure out what to click or double click and what to intersect what with what. But I finally got it to work and have done it several times to make it sink in. And it works like a charm.
          Nice job
          thanks
          Merc
          • daleD Offline
            dale
            SketchUp 8 Pro also has "Solid Tools" which would allow for this to be done, but I noticed your are using 7, which I don't think has Solid tools, so I thought the intersect method would be best.
            • gillesG Offline
              gilles
              There is also the very new Hole on solid
              http://forums.sketchucation.com/viewtopic.php?f=323&t=41582&hilit=hole+on+solid#p368373
