🔌 Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
Easy hole question
5 Posts 3 Posters 1.0k Views 3 Watching
    merc
    this is def a newbe type question.
    How can I draw a hole from a flat surface to an angled surface?
    Example: A 1x6 board.. saw the end off in a 45 degree..tip board on edge.. drill a hole perpendicular to the edge so that it comes out in the center of the angled cut.
    When I push the hole I can't stop it on an angle. It is either not seen or looks like a rod protruding from the angle. I need the face of the hole flat to the face of the angle.
    Probably will step x step instruction for this simple mind.
    Merc
      dale
      You are actually doing everything right. when you get the "rod" pushpulled through, double click to highlight both objects, and go to Edit/Intersect Faces. Then just delete the unnecessary faces, and your hole will remain.Screen shot 2011-12-19 at 6.58.37 AM.png
        merc
        thank you
        It took a few times (yea right - probably a dozen) to figure out what to click or double click and what to intersect what with what. But I finally got it to work and have done it several times to make it sink in. And it works like a charm.
        Nice job
        thanks
        Merc
          dale
          SketchUp 8 Pro also has "Solid Tools" which would allow for this to be done, but I noticed your are using 7, which I don't think has Solid tools, so I thought the intersect method would be best.
            gilles
            There is also the very new Hole on solid
            http://forums.sketchucation.com/viewtopic.php?f=323&t=41582&hilit=hole+on+solid#p368373
